Question about Turboair M3R472 (47 cu. ft.) Commercial Refrigerator
Level refrigerator on wheels
How to level a refrigerator on wheels. turbo air M3R 47-2
Doors do not self shut. Stays open a little bit. Can the doors be adjusted or do springs have to be replaced?
there are no springs . check to see if it is level or just slightly off lower at the back helps close the door
May 14, 2016 | Turbo Air TSR-49SD Stainless Steel...
Can you replace the door sliders on the tst-28sd-d2 one of the guides broke
You should be able to find the part at this website. They have a full line of Turbo Air parts for commercial refrigerators.
https://www.kitchenstuff.com/turbo-air-greenworld.html
Sep 13, 2015 | Turbo Air TST-28SD-D2 Super Deluxe...
Why my Nissan terrano M3R 4wd drive gear stick wont stayin low range
check iff its an adjusteble chifter.if not you have to replace the cabble,
check also transmission fluid level is correct.
Jul 26, 2014 | Nissan Terrano Cars & Trucks
Whistling when accelerating outlander turbo diesel
turbo whistle is common as it comes from the tips of the compressor wheel passing through the sound barrier and the turbulence occurs. IN the older trucks you would the turbo whistle as the engine reached full RPM just before a gear change. In smaller engine it is not do noticeable as there is an excess of air pressure that keeps the compressor wheel at a lower rpm and the pressure is dumped out. Turbo compressors reach revolutions in excess of 120.000 rpm under full load If it has just started to make the noise then check the intercooler system for leaks--loose clamps--- splits - Have the turbo compressor checked for damaged fins from the ingress of fine dirt from a bad air filter---check the air filter is not blocked as the turbo speed may result from running in a partial vacuum ( no load on the compressor wheel)
Jan 07, 2014 | Mitsubishi Cars & Trucks
Door lock for Turbo AIR
How to remove the 3 locks from the panel. Both side of the panel are riveted. How to remove the panel to reach the 3 locks.
Jul 21, 2013 | Turbo Air Reach-In Refrigerator- 3...
Our GDM-47 refrigerator is not cycling on and off. we changed the temperature control
Is it getting cold enough to cycle off. Should be around 10 degrees in the freezer.If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will gradually cause it to warm up because ot the blocked air flow.
Aug 30, 2009 | True GDM-47 Refrigerator
Self closing doors don't self close any more
This problem can be corrected by adjusting the hinges.
May 09, 2009 | Turbo Air MSR-49NM Refrigerator Commercial
KitchenAid Superba humming
First to adjust the leveler/wheels you will need to remove the front grill/toe plate. On the left and right sides you should see some bolt heads that are about 1/2" hex head. One on the left adjust the rear leveler/wheel and the other on the left adjust the front leveler/wheel. Turn the hexhead clockwise to raise cabinet higher counterclockwise to lower cabinet. The right side is the same.
Now to your noise, it sounds like you may have pushed the cardboard air dam under the condenser and condenser fan motor near the compressor up into the fan blade area. Carefully follow the source of the sound and you will find what is out of its proper position.
I hope I helped, supertechks
Nov 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Turboair M3R472 (47 cu. ft.) Commercial Refrigerator Logo
20 people viewed this question
Top Turboair Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
