Question about Whirlpool Refrigerators
Led flickers Whirlpool Gold Model number GI7FVCXWB00. LED Lights flickering when you open side by side doors. The open door Indication on the display is flickering as well. Unit is cooling fine. Please advise...
3 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: Refrigerator lights both not working.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Sea Breeze
  • 4654 Answers
SOURCE: I have a black side by side Whirlpool Gold
I need to confirm your model number. Is it as listed GD2SHAXLQ Reason is there where many different designs. You are saying that the temperature logic at dispenser control has gone out of control and flickering? The part number for the parts to fix and replace that are Click Here=> 2252080B Front cover assembly (black) There is no photo but here is a link to that parts photo and location 23 is ClickHere=> 2252080B Front cover assembly (black)
I think we need to check that part and the wiring going to that diaplay because it appears there is a short circuit. I have the service manual and can assist you if you would like to do this yourself, just let me know, Thank You, Sea Breeze
Posted on Oct 14, 2011
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Apr 01, 2015 | Whirlpool WRS325FDAM 25.4 cu. ft. Side by...
GS6SHEXN500 fridge light and display on temp control flickers and sounds like relay making noise
The problem could be very well a relay that has the contacts pitted or weak causing the lighting in display and the interior lights to flicker. Here is a GS6SHEXNS00 Parts List and the relays I can see are in a covered control box near the compressor on page 17 and 18 on the parts list 2304056 Electronic Control I will be here if you should have any questions, Thanks Sea Breeze
Apr 01, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a black side by side Whirlpool Gold Conquest Refrigerator. Yesterday morning it was fine, yesterday late afternoon I opened it and the light is flickering and the temperature display is not...
Oct 13, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
The does not completely close and one light is green and one yellow i see no disruption. then it opens up again what can i do?
Color of lights doesn't matter. If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are not flickering ever so slightly. Tweak them a little. On the rear of the motor unit there is a small LED. Check to see if it is flashing a code. It will flash a number of times, pause and then repeat. Near where that LED Is you will find the down force adjustment. Increase it about 1/4 turn and try. If the LED is flashing code 5 you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
May 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit...
the clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Strange noise when door is open, light barely flickers, LED out.
I would try replacing the bottom door cam assembly. I have also seen the actual cabinet making a popping noise during opening which is there is no cure for that.
Apr 08, 2009 | Refrigerators
Remote doesn't work!!!
You could try to replace batteries. May be they are stong enough to make the LED flicker, but not strong enough to send out a proper signal to the receiver.
Mar 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
