Question about Crosley CR248 Turntable
CD will not finalize
I finally got a cassette recorded to a CD which I was able to play on my CR248. However, after leaving the machine flashing "finalize" for almost 24 hours that function would not work.
  • Crosley Master
  • 5,056 Answers
No-way should it take that length of time to finalise anything. My DVD recorder only takes about 3 minutes at the most to do a 4 hour disc! CD are only 80 minutes max. I suspect you have an electrical fault on the unit. I would take it to the nearest Crosley Repair place.
Posted on Apr 07, 2014
TDK DA-5700 records from cassette to cd-R but nothing happens when I press FINALIZE and then PLAY (ENTER). Why?
Finalize is for multiple recordings. If its a single recording, its finalized by itself.
Feb 09, 2012 | Audio Players & Recorders
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
Just bought a used sony cfd-c1000. It will play most of my burned cd's but not one specific one: they are all on cd-r and I burned them all the same way with the same program, any ideas why it won't work?
My first two thoughts are: 1) It's a defective disc or 2) The disc wasn't finalized after it was burned. CD-R discs will not play on any machine other than the one that they were recorded on until they are finalized on that recorder. If it will play on the recorder and it has been finalized then just burn another copy of it. I have seen disc compatibility issues on one disc out of a stack of 100 before.
Nov 27, 2010 | Sony CFD-C1000 Cassette/CD Boombox
I have tried to record from Tape to CD with No result. I have followed the instructions for this task, to the letter and still nothing on CD.
First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
Oct 30, 2010 | Electro Brand Nostalgic Stereo CD Music...
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
Hi, the crosley will no longer record onto any music cdr/rw. It will indicate that the cdr is blank-i know it is- then the zeros/record appears but no recording takes place. thanks if you can help.
I turned it off for two (2) hours - turned it on and it worked. Apparently this unit overheats after one session: one (1) cd-r per session then shut-down.
It is worth it, when it works, because my lps have no hiss when finalized.
Sep 05, 2008 | Crosley CR248 Turntable
Crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Jan 22, 2008 | Crosley Songwriter (CR248) Shelf System
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
Crosley CR248 Turntable Logo
124 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
