Question about Sanyo DP50747 50 in. Plasma TV
Where power supply
Where the power supply on 50" samsung PN50B400P3D switching on and off power cycling
    Top Expert:
  • Sanyo Master
  • 75,581 Answers
HI
Please contact the authorized service centre. It will be best in this case. Gopakumar Gopalan Google
Posted on Mar 28, 2014
Samsung pn51 continuously cycles on and off (clicking).
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
Easy fix for new Samsung TV switching on and off power cycling.... My tv turns on and off by itself the ...
Samsung 46" LCD TV (LNT4665F) turns off and on over again -
Dec 09, 2015 | Samsung Televison & Video
look for bulged capacitors and replace them. Amazpn has a guy who sells kits of cpacitors for most TVs and Displays, but a local electronics parts house is cheaper and faster. Make sure you get 105 degree Celsius capacitors.
Mar 27, 2014 | Samsung 50 in. Plasma TV
Our Samsung HPN5039x Plasma TV isn't turning on: when we press the power button, the red power light flashes then turns off. What do we do?
Hello, It sounds like you have a defective power supply. Typically, +5 volt stby is present if the TV switches on with front indicator light. On the power supply, connector 802 pin 4 is the on command from the pcb main to switch the p.supply on. If this signal is present but still no VS,VA,VE panel voltages are missing, the p. supply is bad. Good luck!
Bill W.
integrityhomeworx.com
Dec 24, 2010 | Samsung HPN5039 50 in. Plasma HDTV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My tv is a samsung rearprojection and every time i switch it on it gose strate to standby
The first place to start will be the Main power supply. Any time the set shuts down and goes to standby is a symptom of a bad power supply. I recommend replacing the power supply unless you are skilled in component level repair.
Apr 13, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
PSU problem
The most likely problem is something dragging down the power. There could be a problem within the power supply as well. This is a "switch mode" power supply. That means that if the primary side does not oscillate correctly, you will get this cycling as well. These are hard to diagnose remotely. Typical power problems such as this run about $15 or so for parts plus the local labor rate if it is within the power supply. The parts cost will rise to the $30-$50 range if the output amp section is the problem.
Dan
Mar 28, 2008 | JVC TH-S5 System
Sanyo DP50747 50 in. Plasma TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
