Question about Casio XJS33 Projector
Casio xjs33 has no power
No power light, no status light.....nothing. Are there some basic things I can eliminate other than the power cord and fuse?
Does my Casio g-200 keyboard have a fuse ? If so what type and where is it ?
I'd go exchange the power supply for the correct one (check the voltage, polarity and mA rating that's marked next to the power input). It may be too late, though.
There will be a fuse on the internal power input board, as well as one in the power supply, but if the instrument is turning on and lighting up, it's not a blown fuse.
Jun 29, 2016 | Casio Wk-200 Wk200 76-key Digital Personal...
Green light comes on showing tv getting power but nothing else happens. screen remains black and there is no sound either.
power supply if only the light comes on---basic is follow power cord inside and see if any bad fuses or puffed up caps in power supply but beyond that need a meter to test things and be able to trouble shoot.
above is typical fuse and next are bad caps:
Nov 08, 2012 | Marantz PV-5571 55 in. Rear Projection...
No power, no lights,
The basic things would be to check power source, follow power cord into set and check the fuse there---beyond that it would require some knowledge to look for power supply board and do some tests.
Nov 07, 2012 | RCA L40fhd41yx9
My dell inspiron 6400 won't start, red light then green light flashes ansd nothing happens, try to take out the battery and putting it back, no results, help
The following troubleshooting guidelines are basic troubleshooting steps. Battery Charging It is recommended to charge the battery while the system is off for faster charge times. Users may notice longer charge times when the system is powered on and running graphics extensive applications.
No POST If the system does not perform a Power On Self Test, there are various things to look for:
  1. Check to ensure that the system has a power light.
  2. If the system has no power light, ensure that it is plugged into AC power. Remove the battery.
  3. If the system has power but is not performing a POST, check to see if the keyboard status lights flash to indicate a successful POST, but no video, or that the keyboard status lights are lit in a sequence indicating a system problem.
  1. With the power off and the system unplugged, remove all CRUs from the system and reconnect that AC adapter to the system and try again.
  2. Run the On Board Diagnostics (OBD).
Video If the LCD on the system shows no display, or has other LCD problems, there are some basic steps to take:
  1. If the LCD is not displaying video or the video is garbled, run the BIST Test.
  2. If the LCD is not displaying any video, connect an external monitor to eliminate a no POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  3. Connect an external monitor when possible for all LCD related problems, to help eliminate a software possibility or video card problem.
  4. If the LCD has extremely dim video, attempt to adjust the brightness or connect an AC adapter to eliminate a power management conservation setting set in the BIOS.
  5. If the LCD has lines on the screen, check the system during POST as well as system setup to verify if the lines are present in all modes of operation. Run the BIST Utility.
  6. If the LCD has color problems, run the BIST Utility.
  7. Run the On Board Diagnostics (OBD).
Jul 19, 2011 | Dell Inspiron 6400 Notebook
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
It won't turn on. the power buttons light is not on or anything please help!!
start simple, use the process of elimination wall outlet power cord cord connection to the console is there an internal fuse setup in the Wii even though the power light is not on, did you try the console anyway;meaning the power on light may have failed
May 30, 2010 | Nintendo Wii Console
No power - all status lights are off
Make sure all the doors and covers are closed. If nothing happens and the FAN does not run then there are 2 fuses FU101 and FU202 on the DC controller board. Also check that rthe scanner assembly is correctly seated on the DCA Controller board.
Sep 30, 2009 | HP LaserJet 4L Printer
Casio TE-8500F won't start
On some cash machines there is a fuse that can burn out. Normally this fuse is located underneath where the cord go in.
Most cash machines when nothing happens means it is dead.
Mar 16, 2009 | Casio Parts Cash Register PC Desktop
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Denon AVR 3806 - No Power
open unit replace fuse....im sure u have blown fuse..
rate me fixed ok
Feb 14, 2008 | Denon AVR-3806 Receiver
Casio XJS33 Projector Logo
24 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
