Question about Pride Mobility Products Health & Beauty
Remove broken key from ignition
Stored scooter in garage and forgot to remove key from ignition. Had a very cold winter. Not sure, but maybe moisture got in. Anyway, turned key and it totally broke off in ignition. Sent for, and received replacement key. But have NO idea how to remove broken key from ignition. Is there an instrument or tool that might get broken key out of ignition?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
I'd recommend a dental pick.
Posted on Mar 27, 2014
Testimonial: "Thanks. I'll give it a try."
  • 4 Answers
If you have a habor frieght near buy you can buy a cheap small pick set. If possible try to grab it on both sides and it should come out , its almost always worked for me.
Good luck, Rob
Testimonial: "Thanks, Rob. I do have a Harbor Freight close by. Will pick up a pick set."
  • Robert
    Robert Mar 27, 2014
    dental picks are also available at the same place however dont pry with them as you would a mini pick set . the dental pick are not as hard and you can snap the tips off easily. I like to use them as well for this type of problem as well .
3 Suggested Answers
SOURCE: Replacement key and cable needed
Call Mega Motion at 1-800-634-2508, 9am to 5 pm (EST).
Posted on Jun 05, 2009
SOURCE: a key broke off in the ignition of our handicap
This is a common issue with the travel scooters. It is usually an easy fix without having to replace the key-switch.
You need the following tools:
Good eyesight and / or good glasses to see down inside the key switch. A strong, thin needle. A jewelers flat screwdriver or eyeglass screwdriver.
The broken key inside the switch will have a flat back and a toothed topped. The toothed side moves a series of spring loaded pins inside the lock.
With the switch turned to the off position...
Place the jewelers screwdriver down inside the switch where the key's teeth are, pushing back the spring pins, and getting leverage under one of the teeth to lift the key out.
The needle is used to release friction and back pressure off the key back against the switch housing.
Work it carefully and be patient.
Once the key piece is out try ebay for a replacement if needed.
A common key number for Pride scooters is the A126
Posted on Oct 28, 2013
How do i remove the key that is broken in the ignition of my mobility scooter
Gareth, save your self a lot of aggravation and call a local lock smith, they can fix this problem fairly quickly and replace the key. I do not believe it will be too expensive either. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
7 tricks to get broken key out yourself any lock or key
How to remove broken key from the ignition
How Much Does Locksmith Cost CostHelper com
Jun 01, 2016 | Pride Health & Beauty
I have a full propane gas cylinder for my grill in my garage. It is very cold in the garage and I'm getting a propane smell. Does the cold effect this or is there probably another problem?
Cold shouldn't present any special hazard to a propane cylinder. Just make sure the valve is fully off. You can check for leaking with a little soapy water solution around the valve - look for bubbles. If any doubt, remove from enclosed space.
Jan 08, 2015 | Grilling
Maxima scooter key won't turn on
try a (one) drop of sewing machine oil or 3 in 1 to free it up. Over doing it may get oil into the switch under the key tumbler. If everything else fails a new key switch can be gotten from Pride's website
Feb 16, 2014 | Pride Health & Beauty
you might try putting a 'footie' stocking over the end of a vacuum cleaner hose (to catch the part when it comes out) and then pressing the covered end against the keylock hole and the part might just get sucked out
Oct 28, 2013 | Health & Beauty
FIRST TIME IN WINDOW AFTER WINTER AND WHEN I TURN IT ON , I GET A HUM WITH AC BUT NO FAN. FAN MODE DOES NOT RUN AT ALL.
Since you remove the window unit in the Winter and reinstall it in the Summer, as you should. Check the inside of the unit to make sure there's nothing blocking the fan blades. If you stored it in a basement or exterior shed or garage, a Field Mouse may have built a nest in it. Believe me, I've seen stranger things than that happen.
Jun 08, 2011 | Heating & Cooling
My kenmore freezer is in my garage and doesnt keep my food frozen in the winter but is ok in summer, spring and fall. Can you tell me what i need to do?
It maybe too cold in your garage in winter check your owners manual and see what the recommended room temperature is.
Feb 16, 2010 | Refrigerators
Hi - the cenral locking does not work from the key - although the battery was recently replaced - I have tried resetting from the ignition - no luck. Also the central locking has started locking itself and...
just making sure i got this correct, it is a 2006 604? if it is that way to reprogram your key is only through the ignition or through a dignostic system which reprograms both, just checking make sure you do this correctly ( not teaching grandma to **** eggs as you said you have tried) first, incert key in ignition , trun ignition on (dont turn over) hold the lock button for 10 seconds (try being precise on the 10 seconds) switch ignition off, remove key, wait 5 or so seconds ( no less than) and that should be it, hope this helped
Feb 08, 2010 | 2006 Peugeot 604
I have the little gem 4 and its been in the garage over the winter as i've not been out, i took it out today & it wont work when i turn the key there is a constant beeping, i have taken it apart &...
hi, the rear connections to the main frame are a big cause for problems , make sure the contact are clean and there is a actual connection.
Also check the free wheel lever.
Also you may note that if you haven't charged the batteries for a while , they get weak and may need replacing.
Regards
GeWiz.
Feb 01, 2010 | Drive Medical Mini Phantom Three Wheel...
My husband forgot to winterize our Kenmore Elite H3 washer when we moved. It was stored in our garage for 5 months(September - February). When we hooked it up water immediately started pouring from the...
Its most likely the rubber tubing, and sack that connect the drum to the drain pump. You can either remove the back panel, or the panel in the bottom front of your washer to check for cracks in the rubber. It might be as simple as the tube came out of place during the move.
Mar 13, 2009 | Washing Machines
Health & Beauty Logo
250 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
