Question about Samsung 50 in. Plasma TV
50" samsung PN50B400P3D switching on and off power cycling
    New Friend:
  • 56 Answers
Look for bulged capacitors and replace them. Amazpn has a guy who sells kits of cpacitors for most TVs and Displays, but a local electronics parts house is cheaper and faster. Make sure you get 105 degree Celsius capacitors.
Posted on Apr 16, 2014
Samsung pn51 continuously cycles on and off (clicking).
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
Easy fix for new Samsung TV switching on and off power cycling.... My tv turns on and off by itself the ...
Samsung 46" LCD TV (LNT4665F) turns off and on over again -
Dec 09, 2015 | Samsung Televison & Video
Samsung 50" led tv turns on and off
Does it do this with no cables plugged into it? If it does I would replace the power bard and main board.
Nov 14, 2015 | Samsung UN50EH6000 50 LED HDTV
Where power supply
HI
Please contact the authorized service centre. It will be best in this case. Gopakumar Gopalan Google
Mar 27, 2014 | Sanyo DP50747 50 in. Plasma TV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung  50 in. Plasma TV Logo
249 people viewed this question
Jerry Greenberg
Jerry Greenberg
