Mitsubishi medallion hd 1080
I can't get the tv to come on. When I hit the power button it clicks then turns back off. The green light does come on for a few seconds then goes back off.
    Problem Solver:
  • 16 Answers
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Posted on Jul 05, 2014
Maanita
  • 1142 Answers
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
Posted on May 19, 2008
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Posted on Jun 14, 2008
SOURCE: Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
Posted on Mar 22, 2009
brannfenix
  • 81 Answers
SOURCE: mitsubishi 1080 hd ws-65809 wont power up
This issue is almost always caused by a faulty Convergence IC inside your TV. These chips heat up and can become damaged over time. The most common cause I have seen for the picture distortion is the heat of the Convergence IC weakening the solder connection to the TV circuit board. If you look on various messages board you will see people rigging wooden dowels and other items to apply pressure to the chips in order to correct their picture issue. This works because when the solder joint is weakened the chip becomes loose and vibrations or pressure will cause it to work or not work correctly. Aside from all that information the correct fix is to have the IC chips replaces on your TV.
The solutions for this issue are as follows:
1. located a tv repair shop that will replace the parts for you. I had the same issue with my 65" Tv and the quote was $350 for the labor and parts.
2. You can ordered the IC replacements yourself online by going to google and looking up a reseller of the STK392-110 Convergence IC that is inside your model TV. You will need 2 of them and they cost around $6 each. If you have the soldering skills to remove the old chips and install the new ones this is by far the most cost effective route. It is a fairly simple process and guides can be found online.
Posted on Jul 23, 2009
Older medallion 55" 1080...switched itself
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi 1080 HD Medallion
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
