Question about Poulan Garden
Cant put chain bar back on my poulan chainsaw
Perhaps the brake needs resetting and cant see how to achieve this
    Sergeant:
  • 342 Answers
Deborah there is a tensioning screw on the side assembly that will need reducing back. This should allow the bar and brake assembly to go back on
Posted on Apr 06, 2014
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
  • 211 Answers
SOURCE: HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
Posted on Dec 02, 2008
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
lemmingleejn
  • 173 Answers
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
Posted on Aug 01, 2009
How do i unlock brake on a Poulan wildthing 2375 chainsaw
First, stop your engine. Check to make sure that the chain brake isn't engaged. The chain brake can activate automatically by a sudden movement or impact. You can disengage the chain brake by pulling the chain brake hand guard back against the front handle and releasing slowly. If the chain brake is disengaged and the chain does not turn; turn off the saw, then check the drive links on the chain, the bar groove and the sprocket nose on the bar. A burr on the drive links will bind the chain in the bar. If the bar has been pinched, the chain will not pass freely through the groove. If a sliver of wood has gotten into the sprocket nose, it will not turn at all. Also, look at the drive sprocket on the saw itself to see if it has a groove worn into it. A drive sprocket with a groove worn into it will damage the chain.
Sep 12, 2016 | Poulan 2375 Wildthing Chainsaw Gas / Fuel...
My chainsaw wont start.
check the position of the safety lever /clutch as there may be a micro switch that will not allow it to start with the chain engaged
Apr 30, 2015 | Poulan Pro Pp5020av 20-inch 50cc 2 Stroke...
I have a 14" Poulan
Take off nut, remove bar and chain, turn adjusting screw counter clockwise, replace bar and chain tighten screw, replace nut.
Aug 31, 2011 | Poulan 14" Chainsaw
Poulan chainsaw 2150 How do you put the round spring back into the opening at the end of the bar
Not sure what spring we are talking about, is this the anti vib spring? or the chain brake band? there is no spring on the end of the guide bar.
Apr 30, 2011 | Poulan Garden
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
The chain will not move. It is as if the motor has seized and is preventing the chain from rolling on the bar. Do I need to take the motor apart or is the chainsaw permanently damaged
It sounds like your chain brake is set.If it has one?If so you should be able to pull it straight back to reset it.Push forward to set it.If it doesen't have a brake take the side cover off to see if the chain is bound up.
Dec 17, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Bar wont oil
ok the port the oil flos thru is most likely clogged. drain oil pull bar cover off put an airhose in the oil tank and cover around the hose so air cant escape and blow it out it should unstop
Sep 18, 2009 | Poulan PP4218AV 18" Chain Saw
With the chain off the device, I start the engine
Is the Chain brake engaged? It's the plastic "guard " in front of your left hand.
Apr 21, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
