Question about Ibanez Talman Acoustic/Electric Guitar
Don't know how to turn on tuner
Can not figure out how to turn on tuner do i need an amp or what
  • 4 Answers
Put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Posted on Apr 02, 2014
My zoom g1x theres no sound.all power are working lcd light are on.but the sound cannot come out.can any one help me..
What letters / numbers that appears on the screen?
If the display is normal, and you can switch to other banks, and can edit each bank, then the problem of no sound, is at the pre-amp IC input, output amp, or CODEC converter.
This is the overall image of G1X inside.zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-0.jpg Next, we zoom-in the middle of picture above.
See the next picture.
IC2 (left) is input pre-amp IC (NJM2100).
IC4 (middle) is the CODEC IC (WM8734).
IC5 (right) is the IC output (NJU7082).zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-1.jpg
Test whether the input IC is working normally, turn ON G1X, plug the guitar, go to BYPASS/TUNER menu. When the TUNER function could work, certainly input IC is not damaged.
Means only two possibilities, namely CODEC and output IC. That is not easily tested, except in specific ways.
May also, there are problems in the input / output socket.
Turn ON G1X. Try the following (see figure below):
  • Test the output socket. Touch pin output socket (right red arrow) with finger / screwdriver / whatever. If sound is heard in the amplifier, the output socket is normal.
  • Test the input socket, Same as above. (left red arrow). (if this happen in this point, problem is clear).
NOTES:
If lcd light are on (as you say), but appearing G1 or d5 or bt, and the system are hang / frozen, this is a different issue to the one described above,and dealt with in different ways too.
References IC datasheet:
NJM2100.
http://www.njr.com/semicon/PDF/NJM2100_E.pdf
NJU7082
http://www.datasheetarchive.com/dlmain/Datasheets-22/DSA-439015.pdf
WM8734 http://www.cirrus.com/en/pubs/proDatasheet/WM8734_v4.4.pdf
Sep 10, 2015 | Zoom Music
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
Dec 30, 2014 | Fender Music
How do I use a Seiko electronic tuner?
Hi! Have you read the manual? That is a good place to begin. Maybe you did not get one (if you bought your tuner used, or found it, or stole it, or something). You did not mention your model number, but one of the really common ones is the SAT500. Here's a download site for its manual:
http://www.manualslib.com/manual/657760/Seiko-Sat500.html
Just stay cool. Concentrate on one thing at a time. And take your time. You will soon become a competent user. I think you will find it pretty easy, once you get a good start. Truly.
Jul 24, 2014 | Seiko Auto/Manual Chromatic Tuner...
Hi, I have a problem with my ibanez ew20ase preamp tuner, it was working fine yesterday, now today it doesn't turn on at all, I've tried new batteries but to no avail, also, when I amp it up, preamp works...
I can't seem to find info on this preamp but, that sounds like a power supply problem, considering, the tuner is the part of the circuit that would need power. Volume and tone controls don't, unless they are active,(which I've never seen a reason for). I would try a new battery, because I think you left it on overnight, check the slot for corrosion or a loose wire or connection.
Dec 02, 2013 | Music
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
I plug my guitar to the amplifier and i get no sound at all..... only if i press the tunning button turns on & stays on for couple of minutes and then it goes off again....what can i do? P.S.: The...
The tuner on this is weird. It requires three presses of the tune button. Read your manual... One press turns on tuner and passes audio till it times out. A second turns on tuner and kills audio... the third press restores audio... Others have had the same problem understanding this three mode thing and the timeout in the first two modes is confusing when sound disappears.
May 14, 2011 | Takamine EG340CLH Acoustic-Electric Guitar
I have a takemine 523 12 string. recently, the preamp starting flashing arrows up and down, the tuner is inop and can't get sound through the amp. Any suggestions?
I have this same problem. I press the button to turn the tuner on and nothing happens except the arrows on screen flash alternately. There's also no sound from the output
Feb 17, 2011 | Takamine EG523SC12 Cutaway 12-String...
Hi! My TP-4T preamp works (sound present on AMP) while tuner ON only. After tuner automatic turn-off, sound stoped as well - some noice only. Can I repair such problem myself (I have an experience in...
Hello,I am a guitar tech in Nanaimo,BC,Canada and have run into this problem before.Simply replace the Takamine output jack [where the guitar cord goes into] 3 screws and solder,and it will work fine again.The jack has a switching mechanism in it and when it fails it shorts the output out.The jack is available at most Takamine dealers or Allparts http://www.allparts.com/SearchResults.asp?searching=Y&sort=7&search=jack&show=20&page=5
Feb 03, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Jan 05, 2010 | Music
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
Ibanez Talman Acoustic/Electric Guitar Logo
121 people viewed this question
Top Ibanez Music Experts
Wayne Tolonen
Ted Maxwell
Kyle Steven OHare
Kyle Steven OHare
Are you an Ibanez Music Expert? Answer questions, earn points and help others
