Question about 1995 Yamaha YFM350 Big Bear 4x4 ATV Plug-In Electric Regulator /
Trying to take apart Front wheel cyclinder on 1995 Yamaha Big bear ATV, so it can be rebuilt
Any suggestions on how to get the front wheel cyclinders apart. Its like they are frozen and won't come a part without breaking
  • 814 Answers
If it is like a car and you want the pistons out. Dump out brake fluid and put some type penetrating oil inside for a short time. Use compressed air to blow pistons out. Stay away from the ends of the cylinder so you don't get hit.
Posted on Apr 04, 2014
Nissan Tiida 2007 model vehicle problem the abs kicks in but no light on the dash. It would kick in while stopping at a stop street or anywhere but intermittently. Brake discs/pads tyres replaced.
try bleeding lines, that can happen with air bubble in check valve, some check valves have a bleeder on them, if not set emergency break on rear it will push fluid back to master cyclinder, for front wheels collapes calipers to push fluid back. first look at mater cyclinder if tilted up you may need to lift front or back to level cyclinder before starting. Have used a baby nose cleaner to remove air bubble from master cyclinder be sure engage break padel when pulling fluid from master cyclinder
Sep 19, 2017 | Nissan Cars & Trucks
Atv yamaha big bear 400 4x4 4 wheeler
Sounds like you will need to extract both parts of the broken shaft and replace with a new one.
Apr 24, 2013 | Cars & Trucks
Why do brakes go to floor but still have light pressure?
It sounds like you have air in your brake lines. This is usually caused by a very low brake fluid in the master cyclinder.
To fix this problem fill up the master cyclinder with brake fluid and bleed the front wheel brake cyclinders until the air bubbles are removed. Keep the master cyclinder topped up with brake fluid. Then bleed the rear wheel brake cyclinders until the air bubbles are removed. Don't forget to top up the brake fluid in the master cyclinder.
Dec 31, 2011 | 2004 Chevrolet Cavalier
How do I get the snap ring off the front master cylinder to take the insides out and clean them. Its off a 1982 Goldwing GL 1100. I can't even see the snap ring inside.
peel back the ruber boot, it may tare on the way out, normaly if you intend to remove the insides it would be a good idea to buy a repair kit, you would get a new boot, seals and clip, if you are unsure about the integrety of the master cylinder replace or repair it. paul
Dec 14, 2010 | 1982 Honda GL 1100 Gold Wing
Misfire in # 2 cyclinder trying to locate
Driver side first cylinder.
Driver Passanger
FRONT
2 1
4 3
6 5
Jul 02, 2010 | 2004 Nissan Maxima
No front brakes on 95 yamaha big bear atv
gravity bleed. make sure fluid is always full. crack open the bleeder screw and let the brake fluid drip until no bubbles. Then close bleeder top off fluid and replace cap. Now, pull the brake handle. If there is no pressure or has bleed down, the master cylinder is kaput.
Jun 18, 2009 | 1995 Yamaha YZF 750 R
No front brakes on yamaha atv
if they are drum brakes you may need to adjust the starwheels between the brake shoes. just like old car brakes
Jun 09, 2009 | 1995 Yamaha FZX 250 Zeal
Bottom wheel of 2 of the front wheel cyclinder leaks
they need to be replace with new ones ,because it is cheaper on the long run,
I did it my self and have to do it again,so now i always instal new ones.
Feb 19, 2009 | Plymouth Arrow Cars & Trucks
Rear Wheel Cyclinder
Measure the old rear wheel cyclinder and it should find out if you have 9" or 10" cyclinders or you can take it to the auto parts store and they can match it for you.
Jan 01, 2009 | 1998 Dodge Dakota
1995 Yamaha YFM350 Big Bear 4x4 ATV Plug-In Electric Regulator / Logo
73 people viewed this question
Top Electrosport Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Electrosport Vehicle Part and Accessory Expert? Answer questions, earn points and help others
