Question about Bowflex New SelectTech 1090 Adjustable Dumbbell Single
One of the plates is stuck on the ********. It comes out of the holder regardless of what weight i select. How can i get it to go back into the holder?
Its the outside most plate (the smallest one) and even when i place it in the other holder, or turn it around on the same one, it will not lock into the holder and comes out every time i remove the ********
5 Suggested Answers
  • 3 Answers
SOURCE: weight wheel moved from 25 to 30 while outside of
Push button under on the bottom of the handle to release the adjuster. If it was moved while out of the little stand it may be damaged or not working well. If it was a fluke, just push the button take all the weights off both sides and start over on 5. That button should normally only be depressed when the handle is seated in the stand.
Posted on Mar 30, 2010
SOURCE: One of my Bowflex Dumbell's dial will not turn,
Hi there, I wanted to add my solution to these as I bought a set of second hand bowflex dumbbells only to find one of them wouldn't turn. The dail kept sticking or just not turning. After hitting goggle and coming up blank i turned to the tool box lol I set the bar to 5lb both sides and removed the handle, leaving all the weights in the base, I then removed the weights from the base one by one. Once the base was empty I replaced the empty handle onto the empty base and tried to turn the knob, it wouldnt turn, on the base there are two metal hooks, these stop you pulling the handles out In between weight settings, the metal hook on the base was hitting the metal disk (which has many hooks all around it) on the handle. I lifted the handle off Swaped sides and it still was hitting the metal base hook. If you undo the 6 screws on the underside of the base and pull apart the two halfs you will find a large black square which is held in place by 2 more screws, remove these and pull out this square, you will now have access to the underside of those two metal hook (which are held in place by two screws each) undo these a little and push back on the hooks and retighten these screws, turn the base over and replace the handle to see if the dial will turn freely on the base. Replace all the screws, re fix the two base halfs together, sit the weights down in the base, place the handle back and turn that dail Hope this helps someone.
Posted on Feb 11, 2012
SOURCE: Bowflex Select Tech was dropped and the plastic frame broke. Can it be fixed?
two of the plates have broken, the plastic nipple that holds the plates to the handle have broken off. therefore, the plates do not stay connected to the bar. will bowflex send me new plates? can i send them back and have those plates repaired? or do i have to purchase replacement plates, if so, please share...thanks!
Posted on Aug 06, 2012
leanicholson
SOURCE: Weight Plate falling off
Thank you! I found the reset button and now it works again.
Posted on Nov 24, 2012
The cupholder in my Montana is stuck,and won't come out...what do I take apart to get it back out?
Dash Cup Holder is stuck and won't come out, how do I fix ...
www.fixya.com/.../t10005627-dash_cup_holder_stuck_won_39_t_come
Aug 5, 2011 - Dash Cup Holder is stuck and won't come out, how do I fix it? - Saab 2004 9-3 ... How do I remove an in-dash cup holder in my 2005 Chevy Malibu. Apr 26, 2014 ' 2005 ... Nov 05, 2012 ' 1999 Pontiac Montana ยท 1 Answer ...
cup holder montana van Questions & An
Dec 26, 2015 | Cars & Trucks
Shower head stuck in middle selector
sounds like the link between the selector lever and the internal control surface is broken or stripped. if the unit can be disassembled without damaging any parts, then looking in side will likely allow identification of the problem.
Mar 19, 2014 | Hansgrohe Raindance 27483001 Chrome 6"...
What sizes do weight training plates come in?
Weighttraining plates come in a variety of s. In the average gym, the platesusually start from 1.25 kg all the way to 25 kg. In between you can find 2.5kg, 5 kg, 10 kg, 15 kg, and 20 kg plates.
Jul 25, 2012 | Exercise & Fitness
Selector knob spins, no clicks, does not select the weights. The metal disk near the handle does not move.
1. Check to assure that the ******** handle is fully depressed into the ******** base. If not fully depressed, the locking mechanism will not be released and may be keeping the adjustment knobs from rotating. 2. Check to see if any weight plates have been put into the base assembly backwards with the "support ******" facing the grip of the ******** handle. All weight plates must have the selection ****** facing away from the grip of the ******** handle. 3. Check to see if there is any dirt, debris or other obstruction in the ******** base. You may need to remove the weight plates from the base to accomplish this check. Remember to put each weight plate back in its appropriate location with the selection ****** facing away from the ******** grip.
Aug 15, 2011 | Bowflex Selecttech Dumbbells
Once the dumbell is on the base the dial will not spin so you can not pick up any weights. I can push the putton on the bottom when I am holding the unit with out any wieghts and the dial will spin but...
Try setting the handle in the plates back onto the carrier(bottom). Lightly tap on each plate that is stuck. Now push the plates down (vertically) onto the bottom carrier. Now try turning the dial (side that was stuck). It worked for me. Have my 1090 plates were stuck on the handle. Good luck
Jun 11, 2011 | Bowflex Selecttech Dumbbells
My bowflex dumbells are jammed and i cant remove them from the holder
Hi I called 1-800-628-8458 (the number in the manual) after trying several of the methods shown here. None worked. your dumbbell needs to be on a flat surface, no roll the dumbbell over to where the weight is facing the floor and the base is up in the air. With both hands lift the base and gently shake, the weight should fall out. Put the base back on the floor face up and inspect the grooves where the weight plates go for any debris. Clean this area if you find debris. Now you will need a pen or pencil with your weight. Grab your weight, still facing down and you will see a black release button on both sides on the inside of the weight. It is in between the metal dial and the inner part of the weight. Now press down on that button with your pen or pencil and start turning the dial (caution: the weight plates are going to fall out) keep turning until all of the plates are out. Do the same thing for the other side. Now grab each plate and put it back on the base where it goes, the smallest plate on the outside to the largest plate on the inside, make sure the small metal piece on the bottom of each plate is facing away from the inside of the base. Do this for all of the plates. Now back to the dumbbell. Grab your pen or pencil again and press down on the black release button and turn the dial to where the number 5 or lowest weight is selected where it reads Bowflex. Do this for both sides. Now grab your dumbbell and carefully put it back into the base. It is important that you put the dumbbell down straight, avoiding any shifting in plates.
I hope this helped.
Dec 21, 2010 | Bowflex Selecttech 1090 Dumbbells
The selecttech dumbell adjuster will not move. It says there is 7.5 lbs on the bar and there is actally only 2.5 lbs. The adjuster wheel will not turn. How do you fix it?
Push the button on the bottom of that releases the adjuster to spin. Set both to sides to 5, put all the weights back and your ready to place it back and select a weight.
Jan 21, 2010 | Bowflex Selecttech Dumbbells
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Need to replace the rear rotors on the ford f150 2005 4x4
yes they should come off unless they are stuck. this is where the problem arises. if the rotors are stuck. what you can do is slam the whole piece where the rotor is on a block of wood so that it won't be damaged. but the rotor would not be touching the wood. let the weight of the rotor force itself off it's holder.
as it comes off, you could notice the rust that have caused it to stuck.
clean it thoroughly before assembling back.
i hope i was able to help,
drcool
Aug 17, 2008 | 2005 Ford F-150
Bowflex New SelectTech 1090 Adjustable Dumbbell Single Logo
64 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
