Question about FireLite (USBFLB80) Hard Drive
Need data transfer cable for firelite usbflb80 hard drive
Lot data transfer cable for firelite usbflb80 hard drive
  • 2 more comments
  • Hannah Johnson
    Hannah Johnson May 20, 2014
    As it turns out, the data transfer cables I have work with laptops but not my Lenovo desktop. What's that all about? I have to prop the drive on a stack of CD's, because i Have one extension usb that allows me to work from the desktop.
  •  Mike M
    Mike M May 20, 2014
    That makes no sense to me.
  • Susan Dew
    Susan Dew May 20, 2014
    No, it doesn't. But it's true. My Lenovo all-in-one desktop has the USB ports on the side of the system, and they are vertical. I have a USB extension that works with the Lenovo and the laptops, and I prop the drive on top of a stack of CD's and I'm good to Go.
  • Susan Dew
  • FireLite Master
  • 3,320 Answers
Why doesn't the USB cable work?
Posted on Mar 28, 2014
  • 224 Answers
SOURCE: Hard Drive RAW System
Run diagnostics on the drive it may be failing. If it's ok you can try to reformat it from Windows Disk Management.
Or if you need to recover data for remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Posted on Sep 12, 2012
lambylamb
  • 113 Answers
SOURCE: firelite wont mount on my computer
look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Posted on Oct 09, 2007
bschilz
  • 2049 Answers
SOURCE: how to backup your computer onto a firelite hard drive
It won't show up on your desktop automatically.
Go to Start > Computer and you should see it listed under Devices with Removable Storage.
You can create a shortcut there for your desktop.
Using Wndows Explorer, you can copy and paste the files you want to back up from your C: drive to your Firelite.
Posted on Oct 18, 2009
Beni S-P
  • 1006 Answers
SOURCE: Firelite Hard drive read as "local disk"
1)Run CHKDSK ON that disc
2)Run antivirus to scan disc
Posted on Dec 28, 2007
prashant2012
  • 1127 Answers
SOURCE: Im trying to access my
Hi
A USBFLB80 is not a hard disk controller, it's an external USB hard drive and does not require any driver when used in Windows ME/2000/XP. This device is plug and play in Windows XP providing you have a working usb port to plug it into.
Posted on May 29, 2011
Wanto erase all data from firelite backup drive
You could try data rewriting software to erase your data, like AOMEI Partition Assistant Erase hard drive feature: http://www.extend-partition.com/help/wipe-data.html first you need to connect this disk on your computer and then download the free version of Partition Assistant to use.
Sep 25, 2012 | FireLite (USBFLB80) Hard Drive
Sep 11, 2012 | FireLite (USBFLB80) Hard Drive
Im trying to access my firelite external hard drive (model USBFLB80) that has been sitting around unused for a while. I have a new computer, which is a mac, now and only used it with a windows pc before. I...
Hi
May 29, 2011 | FireLite (USBFLB80) Hard Drive
Need to purchase cord that will allow me to go from firelite to usb for new mac computer
Along with the Firewire port, there should be a standard USB 2.0 port on your drive. In that case, any standard USB cable will do. If for some reason there isn't a USB 2.0 port (?), you can purchase
a USB/Firewire adapter for about $1.50 at Monoprice.
Jan 08, 2011 | FireLite (USBFLB80) Hard Drive
What kind of external power supply does it need if
Portable HDDs normally have a dual cable USB with the thicker cable being the power and data and the thinner one power only. Many manufacturers now make PSUs with USB sockets
Mar 06, 2010 | FireLite (USBFLB80) Hard Drive
I have a firelite smartdisk portable hard drive usbflb40. I need th driver for it. Where can I down load it. Thanks
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/SmartDisk-FireLite-Driver.shtml
there you go!
Feb 25, 2010 | FireLite (USBFLB80) Hard Drive
Power connection, but no Data (Mac)
The first and simple thing to do is to try a different data cable and see if it works. If it doesn't work then may be it has crashed and you can probably recover it using a recover tool like Recoversoft Data data rescue Pc. Th trial version will let you determine whether you can recover or not. If the differnt cable thing wont work then let me know and i will walk you thru the data recovery process using Recoversoft Data data rescue Pc.
Jul 10, 2008 | FireLite (USBFLB80) Hard Drive
AUTOMATIC BACKUP TO EXTERNAL HARD DRIVE (FIRELITE)
The first thing that comes to mind is the Firelite has become full and can not accept any more backup data.
Delete the data on the Firelite and try running your backup again. If it works then that was the problem.
The backup software should have a configuration setting somewhere that allows it to automatically delete older data and keep it from filling up.
Nov 11, 2007 | FireLite (USBFLB80) Hard Drive
Firelite wont mount on my computer
Oct 09, 2007 | FireLite (USBFLB80) Hard Drive
Problwm using my external hard drive
hey mate only thing i can think of is, on some external hard drives theres a switch on the side that write protects the data, you usually just have to change the switch over and it will work fine :-) all the best John
Mar 09, 2007 | FireLite (USBFLB80) Hard Drive
FireLite (USBFLB80) Hard Drive Logo
70 people viewed this question
Top FireLite Computers & Internet Experts
David Payne
David Payne
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
