Question about Refrigerators
No water coming through door cold water point in door. Icemaker OK.
  • rowen969 Jun 15, 2009
    Model No: LG GR-L207EQ. We think it is probably around a 2001-02 model. We have had a great run with this fridge. Looking forward to your reply. Wendy
    Helpful solution and good description of work needed to be carried out.
    rowen969
    Brigadier General:
  • 8,619 Answers
Hi
Please check your inline water filter, it may need a replacement as filter requires replacement after every 6 months. Please tell me the model number of your Unit so that i can provide you with model specific information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 15, 2009
  • Rylee Smith
    Rylee Smith Jun 15, 2009
    Hi
    You'll need to check the tubing for any blockages and also would need to replace the water filter as it may be clogged up with calcium and other mineral deposits. Remove the fridge toe-plate , notice where the cabinet tubing and door tubing are coupled together, and check for any posible leaks. Also check the water inlet valve at the back of your refrigerator. To buy a new filter for your refrigerator look at this link---
    LG GRL207EQFilter
    Please see this picture to check your filter--
    Picture 2
  • Rylee Smith
    Hi
    LG GRL207EQFilter
    Picture 2
    Thanks
    Rylee
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water flowing into the icemaker. The water is going into the cold water on the door. However, when I take the line off for the icemaker... no water comes out. I see that there are 3 connection for the...
The line to the icemaker won't have water coming out until the icemaker cycles and energizes the solenoid valve. check the inlet tube where it goes into the icemaker. sometimes this freezes shut. you can also check the continuity of the icemaker solenoid.
May 05, 2010 | Frigidaire FRS23R4A Side by Side...
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
I have a kenmore 106.52603100 side by side refridgerator. A few days ago we found water in front of the unit on the floor, it appeared to have come from the ice maker and it is now not working, no water is...
First thing to check is if the water inlet tube is blocked with ice or not. Often this is the case and people have their icemakers replaced with no luck. It the tube is not frozen with ice, then check the arm that turns your icemaker on and off. this should be in the down position. There may be a reset button on the front of the icemaker.
There is one solenoid that control water to the icemaker and a different one that supplies water to the dispenser. Often the Ice solenoid will quit. If you are good with an electronics meter, you can test the resistance across each solenoid....they should each measure the same. If one reads open or much less then the water supply valve is bad.
Nov 29, 2008 | Refrigerators
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Nov 11, 2007 | Refrigerators
Ice maker fails to make ice tried several times to turn switch on and off water flows to the cold water dispenser worked OK for the past several months what to do??
I hate to say this but from experience on LG icemakers if the fingers aren't turning or the if you have the flextray model the only fix is a new icemaker. Make sure the fill tube to the icemaker is not frozen also.
Oct 23, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
