Question about Vtech OfficeMax - Vtech5.8GHZ DSS Cordless I W/ITAD Phone
The phone stop ringing & I can't find the problem
Both bases power light are on
    Problem Solver:
  • 12 Answers
(I am assuming you are a business.) You don't have a power problem, you have a line trouble to or inside the phone itself. Phones operate with two wires: tip or green wire transmit the outgoing sound (voice); the ring or red wire transmit the incoming ringing signal. Your ring side is shorting out after the first ring. This short can exist in a local central office that transmits your dial tone to you; can exist in the underground/airial wires to your buiding; can exist in a wire closet (a riser wire closet from the basement wire closet to your floor); or in your the very base of your phone. You can have your service provider to verify the ring side of your service at the basement equiptment room. They may charge to verify any further; however, it is common to have this short appear from the central office. If the central office is transmitting a good ring side signal, pay a local communications company to verify your line from the basement entry point to your office(s). NOTE: FIRST TEST OUT A CORDED PHONE AND SEE IF IT RINGS OK...THAT WILL ISOLATE THE TROULE TO YOUR PHONE IF THE CORDED PHONE RINGS OK. GOOD LUCK.
Posted on Apr 06, 2014
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
1.800.297.1023
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
My phone won't stop ringing when someone calls. it has a steady ring and it rings after you hang up. the caller id won't pickup who is calling. how do i fix it?
Try to reset the telephone base by unplugging the unit's electrical power. Wait for 15 seconds and plug it back in again. Allow up to one minute for the handset and the telephone base to synchronize.
Apr 01, 2011 | Vtech CS5121 Cordless Phone
Base station on SPP-N1000 rings in steady tone when call comes in and continues ringing after handset is answered. Handset rings normally. How do I fix?
Ok IF you can answer the Call and it still continues to ring, then this is a real wired problem, Usually, the "Ring" cycle, is used to "Trigger" a "Alerting" circuit that then makes a sound, when the call is answered, this "Resets" this circuit. Now IF it does continues, to ring AFTER the handset has answered the call as normal, then obviously, either the handset, is sending the correct signal back to the base, and the base is putting the call through, BUT the Ring Circuit, isn't being Reset. The fault, then must be with the base. You will have to get it looked at. As an aside, when does it stop, I mean it must, or that would have been your query too? No? So I assume, that it does eventually, stop, I expect it would, as usually, you would design in a "Watch Dog" circuit, that would, time out, if the circuit, didn't reset itself after a pre-defined period. So, Thats the Diagnosis, you will have to repair or replace. As usual though, remove from power, reset as if new, if still faulty. You know what to do.
Apr 16, 2010 | Sony SPP N1000 Cordless Phone
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
? how to set the # of rings
there is a ring select button on bottom of phone base. can be 2 or 5 rings
Nov 06, 2007 | GE 26998GE1 Cordless Phone
Vtech OfficeMax - Vtech5.8GHZ DSS Cordless I W/ITAD Phone Logo
95 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
