Question about Video Game Consoles & Games
How to create a clean on wold of tanks
Hot to make a clan on wold of tanks
Suggest me the most popular hacks that have been ever created?
How to hack clash of clans is probably one of the most popular hacks ever created. The Clash of Clans is a smashing success with millions of players logging on every single day to do battle with one another - forging alliances, forming rivalries, and doing everything they can to carve out their own little empire in the digital universe of Clash of Clans. I was very excited to download Clash of Clans game into my mobile device. Thankfully though, there is a way to completely level the playing field, it was the Clash of Clans Hack tool which was very effective, reliable and safe, that helped me to do so!. This is the best hack tools that I have used so far and also I would recommend you to definitely try using these tools, for an effective and easy game!!.
Dec 15, 2017 | The Computers & Internet
Why does saw die after running for a few minutes.
Well, if it is you lucky day it is a plugged vent to the fuel tank!! Loosen the fuel tank cap and see if unit will continue to run with out a problem. If the vent is plugged after a few minutes as the fuel leaves the tank a vacuum is created and prevents the fuel from entering the carburetor.
chainsaw fuel tank vent line repair
If not so lucky it can be the ignition coil that fails when it gets hot!
Chainsaw Ignition Coil Test
One other possibility is that the chain gets tight on the bar when hot. Check tension and oilier. Manually oil just to check it out.
Last item can be fuel/oil mix!! If confusion or what ever has no oil in the mix the piston gets tight against the cylinder creating excessive friction stalling the engine and potential engine damage!!
Feb 27, 2016 | Garden
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Cheat in battle realms in lan games
Lotus Clan instant Yin point trick
Quickly build a Tomb of the Brothers and summon Lythis, one of the brothers of the crypt. Just have him attack a tree and watch yin points add up. This trick works well on a stage with lots of trees. (Note: This was fixed in later patches)
Unlimited Necromancer Spirit Warriors
1: Get a Necromancer(Serpent Clan)
2: Summon 3 of them
3: Save game, exit, start Battle Realms again, load the file and Summon another 3 of them
Instantly destroy enemy buildings
1st: Select an enemy building
2nd: Press ctrl+d simultaneously
3rd: Watch the building turn instantly into dust! This was fixed in the Battle Pack 2 (1.10j) version of the game.
New Lotus Clan Instant Tin Point Trick
You must create a Crypt of the Brothers to perform this trick. Then create either of the two brothers, Lynthis or Tausil. Select it and press f and attack the water and watch your yin rise without hurting mother nature.
Serpent Clan instant Yin point trick
Quickly train a unit into a Ronin and have him learn the Yin Blade battle gear. Take him near a tree and turn his Yin Blade on and force attack a tree. Watch your yin points rack up. This trick is good in a stage with lots of Trees.
Unlimited Brothers
For the Lotus Clan:
1. As soon as possible build the Crypt of Brothers.
2. Train all 3 Brothers (you can use the Yin Farming to make it easier).
3. Build 3 Watchtowers.
4. Put the 3 Brothers on the 3 Watchtowers.
5. Destroy your Crypt of Brothers (CTRL+D x2).
6. Rebuild your Crypt of Brothers.
7. Build the 3 Brothers again.
8. Remove the old 3 Brothers from the Watchtowers.
9. Put the new Brothers on the towers.
10. Repeat.
* Notice * The brothers only use Yin, Rice, and Water. If you destroy your Crypt of Brothers while the 3 Brothers are on foot, they will die with it. That is why if they are one the towers, they dont die. This also makes the computer think they are dead so it allows you to train new ones.
Jun 27, 2011 | Computers & Internet
I have lost my security answer about crossfire . I will go in a new Clan GermanMights. Please help me. Im the leader from the clan *[HD]-Skills .
ok so did your account get stolen or you forgot your password both ways look for the sites support email address or a support number contact them and explain your solution but you have to prove to them the acccpunt is yours tell the date it was created etc pls rate my answers
Dec 21, 2010 | Video Game Consoles & Games
Extending subwoofer cable
The subwoofer signal is fairly hot, so you can go pretty far without significant signal degradation.
Use standard shieled audio cables and cable couplers to do this. I wold say you cold run it 50 feet without creating a problem.
May 06, 2009 | Audio Players & Recorders
IP phone to IP phone through an IP trunk Issue
Is this an IP office? If so, maybe try to untick the "direct media path" box in the extension tab.
Jul 07, 2008 | Avaya 4610SW IP Phone
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
