Question about Panasonic TH-42PZ700U 42 in. Plasma Television
Blinking 1mm green dot on a new panasonic 55vt60
As above
  • Panasonic Master
  • 3,320 Answers
Where on the tv? The screen? The case?
Posted on Mar 27, 2014
Panasonic LCD TH-L32C2OM when I on the above lcd tv green led blinking and within few seconds red led blinking 4 times
Looks like a power supply trouble or capacitors not good. Has to be open and check by a pro. Good luck,
Serge.
Dec 27, 2015 | Panasonic Televison & Video
Plasma tv troubleshooting
If that dot is on the main screen, it means that there is a dead pixel. Depending on the warranty, this might be something that you have to live with.
Mar 26, 2014 | Televison & Video
Somthing is on one of the Mirrors It projects a yellow circle over the image. I have taken the projector apart. I am trying to Remove the board but can't figure out how to diconect the three ribbon cables...
Look at the surface mounted connectors for the LCD panel ribbon cables.
You will notice that the leading edge of the connector closest to the ribbon cable where it enters is a different colour.
Generally its a light brown colour. you gently slide this brown piece towards the ribbon cable about 1mm forward until it stops. then the ribbon cable can be withdrawn away from the connector.
the green lcd ribbon cable is sometime inserted underside. the others above the brown piece.
Note which cables are above and which below when putting them back.
Mar 10, 2011 | Panasonic PT-L785U Multimedia Projector
Green blinking (bottom) light. No paper feed or test print can be performed
O'Neil MF8i Infrared Printer Green light blinking problem,
Solution: There are two types of green light blinking problem slow and fast blinking so in case of slow blinking you should change the IC-LT1776 part location number on the board U14 and if the light fast blinking then need to change the part number U20 on the board.
Note: U20 Can be replace with working one only if you buy new one that will not work because its programmed by the manufacturer and normally U20 become faulty and U14 & U20 location numbers are for the old version board. With the new version board the ICs will be the same but the location number will be different.
Sep 07, 2010 | O'Neil Printers O'NEIL MF8I PORTABLE DOT...
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
