Question about Cell Phones
Power button does not work on my at&t z998
Power button is not turning phone on
How do I unlock my Z998 ZTE I forgot the password
Factory Reset, scrub the whole thing clean.There is no master code or a way to find the code YOU put in it.
Power Down. Hold Volume Up and Power button until you see the Recovery Console.
Jan 09, 2017 | ZTE Cell Phones
The front/back toggle icon is missing on my z998. How do I get it back?
do you mean for the camera? From the camera screen To change shot modes, tap the square icon and select an option. if the issue is something that started after using the camera in another app, you may have to power cycle the phone. If that fails to fix the issue, you may have to take it to the AT&T store to have it looked at. Or, just reset it to factory defaults.
Apr 22, 2015 | AT&T GoPhone Z998 4G No-Contract Cell...
My phone shut off last night and will not come back on
Try removing the battery, the press the power button and hold it for 15 seconds. then insert the battery and try to power the phone on.
Apr 03, 2015 | AT&T GoPhone Z998 4G No-Contract Cell...
Why does my red light flash on my z998 but wont turn on
try pulling the battery out,Just leave it out a few seconds (count of 30). And unplug power(charger) cord from your phone. Then put the battery back in and press the power button.
Feb 08, 2015 | AT&T GoPhone Z998 4G No-Contract Cell...
How do I unlock an ATT ZTE Z998 Mustang
you can easily get AT&T ZTE Mustang Z998 IMEI Unlock Code from zteunlockcodes.com, i got a very fast response and easy solution to unlock my ZTE phone and i found it to be the cheapest way to unlock my phone
thank you zteunlockcodes.com
Oct 09, 2014 | ZTE Cell Phones
How do i get the front camera icon back on my Z998 phone
Manually hard reset or update firmware to solve this problem.. After update firmware the problem still continue most problem in back cammera
Aug 25, 2014 | AT&T GoPhone Z998 4G No-Contract Cell...
When i am talking on the phone, it goes to airplane mode and i cannot use the phone...how do i fix or lock the screen or get the airplane mode off of the quick touches
This will help to reduce the frequency of this issue occurring. I have the same problem and have not yet found a way to remove the Airplane Mode option form the action bar pull-down for the Z998 phone. It is a ZTE firmware issue, not Android.
UNDERSTAND WHAT HAPPENS: when the phone moves slightly away from your ear while talking, the proximity sensor detects that it is not close to your face and it turns the display back on as it should. The screen often comes on with the action bar pulled down and thus all the controls exposed. A moment later your phone touches your ear before the proximity sensor had caused the screen to go blank again, so whatever your ear touches, can become an actual user command, even though unintentional. Unfortunately the Airplane Mode is one of the first selectable options on the Action Bar. You might sometimes notice that Bluetooth, Sound or Mobile Data gets toggle also; at least that does not cause you the dropped call. The problem gets worse when you walk or move around or fidget a lot while talking.
THIS HELPS: manually turn the screen off (press the power button) after you answer the call. Because you deliberately power off the screen, the proximity sensor is bypassed. The job of the proximity sensor is to turn on/off the screen to save battery (the reason of course that when the phone is against your ear, you cannot possibly also look at the screen, hence the proximity sensor turns it off for you). You will soon get in the habit.
Apr 01, 2014 | AT&T GoPhone Z998 4G
Cell Phones Logo
90 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
