Question about Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g
Network Printing (LAN)
I can ping even brows to confirm admin settings but it still cant print.
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam,
Did you give the machine a static IP address or DHCP meaning let the network decide what IP address is issued this machine LOVE static YOU telling it via admin setting on the copier, admin, admin 1, network, basic . set ip, mask etc.
Posted on Jan 01, 2015
Set dhcp on bizhib 250
1-Press "Utility/Counter" button from the control panel.
2-Press "Administrator settings"
3-Enter "Admin Password"=12345678
4-Press "END" button on top right corner of the screen.
5-There are two settings now, Admin1 and Admin 2.
6-Press Admin 2. the network settings
7-Now press "IP settings" in this option there will be two settings one is obtain IP auto and other is put IP manual.
in network settings you will see all the other options such as ping confirmation, DNS HOST, DNS SERVER ADDRESS, DHCP ON/OFF, SMTP etc.
Jan 29, 2013 | Konica Minolta bizhub Office Equipment &...
My Konica Minolta bizhub C280 is connected on the network but when i try printing,nothing happen,no job iin the list,how can i reset the settings on factory settings or how can i solve this problem?there...
Simply uninstall the printer.Restart your PC.Now again install the printer.Use new driver instead of previous drivers.Ping confirmation from PC.Ping from Machine.If connection is okay then there is no need to reset the machine.There is network problem.
Sep 09, 2011 | Konica Minolta Bizhub C300 All-In-One...
I can't get my konica minolta c300 to print through my network nor through a direct connection to any PC since I installed windows 7. Also, I do not remember how to pull up the IP address for the...
First of all bring your machine on network.All you have to do is to just connect the network cable to it.Now press these buttons,Utility/Counter,Check details or details,Now select Administrator,enter admin password which is 12345678.Press enter.Now press NETWORK SETTINGS,In this option go to IPv4 setting. In this option enter IP address manually and put it on manual setting.Now press Details settings, then press Ping confirmation.Enter the IP which you want to ping and press Start button.This is how you can ping any ip address frm machine and bring your machine on network.
May 23, 2011 | Konica Minolta Bizhub C300 All-In-One...
I cant get my computer to find my scanner on my ricoh 2035
if you are adding it to your network... then you are doing ip printing... verify that nobody else on the network has the same ip address by unplugging the network cable from the copier and doing the following... goto start... accessories... command prompt... (black and white blox...) ping the copier... lets say ip is 192.168.168.168 then you ping it by typing ping 192.168.168.168 and hitting enter... if you get 4 time outs then ip is good... next step is to reinstall your print driver...
Dec 08, 2009 | Ricoh Office Equipment & Supplies
Samsung CLP-510 Printer not printing...
Some network interfaces have been found to be defective. Try printing from parallel or usb until you can get a replacement network interface.
Dec 04, 2008 | Samsung CLP-510 Laser Printer
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
