I went to turn my tv (42" Vizio) on this morning and a blue screen came on with the words No RGB, TV will turn off. Pressed every button except on/off button and nothing worked. Help!
    Brigadier General:
  • 8,619 Answers
Hi
Please check the connector cables coming from cable box at the back of your TV. Also try and use HDMI cable and try connecting the DVD player with your TV. If the dvd player works fine then there is an issue with the connector cables coming from the cable box(set-top box).
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 15, 2009
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
This is normal on vizios, ours does it too. You have it switched onto RGB input. You need to change input after it comes on. Switch on and keep pressing change input button till it changes and then it will be fine. Alternatively plug in a computer on Rgb and then turn on, you will be able to change input normally.
Sep 29, 2012 | Vizio GV42L 42 in. LCD Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
TV will not get off the RGB Screen
I just talked to a tech and fixed mine. unplug tv and hold power button for 1 minute. this drains the compasitors, sometimes they get over charged. if that doesn't work. with tv off hold down input button until tv turns on . it should work. here is tech support # 714-668-0588
Aug 27, 2009 | Vizio VX42L 42 in. LCD TV
NO RGB SIGNAL - VIZIO HDTV TO LAPTOP
I've been online looking for a solution to this problem and couldn't find a fix until today. I just got off of the phone with a Vizio Tech. He told me that some pc's have a way for the monitor to show the screen externally, and that there's usually a button, sort of like the input option on your TV but its an output button for a laptop in my case. It should look like a picture of a TV in and out of each other. Mine was located on the number four key. I had plugged in my wires and put the TV input on RGB. then on my laptop pressed the function key and number 4 key at the same time and what do you know, I had a picture on my screen. I almost gave up on my vizio but love it even more now. I hope this helps.
Jul 05, 2009 | Vizio VX42L 42 in. LCD TV
The dogs rolled on the remote and the tv went to a blue screen and turned off. Every time you turn the tv on now it is a blue screen and says no signal and turns off after 10 seconds
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
Mar 22, 2009 | Vizio Televison & Video
When i turn on y Vizio LCD TV theres a blue screen that says no
Your TV is probably in RGB mode which means its looking for a computer signal. Plug a computer into your TV and then it will stay on. Then you can change it back to TV mode.
Dec 24, 2008 | Vizio GV42L 42 in. LCD Television
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
42 in lcd vizio "no signal"
Had the same problem. My TV must have been puht onto RGB input. So I plugged my computer in to the RGB on back and turned on the TV. It stayed on. Then switch it back to input of choice
Apr 15, 2008 | Vizio VU37L 37 in. LCD TV
Vizio L37
try to go to the menu,then find the words,blue on or off,turn it off,then you will see the changers.
Nov 10, 2007 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
