Question about Research In Motion BLACKBERRY Bold 9780 - black
Unlock network service
Supplimentery service error
Can not make calls screen shows no service
Did you phone shows "No service" error?Check whether your sim is placed properly in the slot. Try to reinsert the Sim. Still if you face the same problem then your phone might be locked to particular Network. To solve this problem you need to get it unlocked. You can unlock your phone from Network lock using unlock code. You can get the unlock code for your phone from your Network service provider or any third party online vendors. /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman";}
Feb 28, 2014 | safelinkwireless.com
Tip
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction...
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 07, 2011 | Cell Phones
Nokia asa 305 no network
search manually for network or change your service provider
Jan 21, 2014 | Nokia 6300 Cell Phone
Simlock sgh j700
You can remove the sim lock error from your phone using unlock code.You can get such codes from your Network service provider or any third party online vendors like ClassiUunlocking.com specify your country,Network name to which it is locked,IMEI number of your phone.
Jan 16, 2014 | Huawei Cell Phones
Problems with htc phone
if there's no network it means it has no sim card OR your sim card is not working. otherwise, your phone itself is not working properly. Or go to settings and find the airplane mode then turn it off :)
Jan 08, 2014 | Cell Phones
C170 network problem
I think your Samsung C170 phone is locked with network so that it displays an error message "No Service" .To unlock it,visit the site SimpleUnlocking.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network sim card.
source:Simple Unlocking Unlock the Samsung C170 mobile phone
Jan 07, 2014 | Samsung Cell Phones
Nokia 7230 contact service
If your Nokia 7230 phone displays an error message saying "Contact Service" then your phone is probably network locked.
To unlock it,visit the site Unlock-Zone.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.
Dec 13, 2013 | Cell Phones
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Contact service error after switch on..
It says Contact service provider means it locked to Network,you need to Unlock it,you can get the Network Unlock code from here
Theunlockspot.com
and unlock it from Network lock,find it locked Network,country and specify that...
Sep 20, 2011 | Nokia 5220 XpressMusic Cellular Phone
Wen i switch on my nokia phone i get th error message as cantact service
Contact service mean you need to unlock it , you sim may be restricted to particular network ,If your sim restricted to particular network you need to unlock it , to do so , I would recommend you use unlocking codes as it is one of the safest way , Unlocking via codes is the best method for unlocking the mobile . using the unlock code specified in this site simpleunlocking proceed unlocking your mobile . They are reliable and provide good customer support service.
Aug 21, 2011 | Nokia 5310 Cellular Phone
Research In Motion BLACKBERRY Bold 9780 - black Logo
24 people viewed this question
Top Research In Motion Computers & Internet Experts
David Payne
David Payne
Are you a Research In Motion Computer and Internet Expert? Answer questions, earn points and help others
