Question about Jensen Televison & Video
Remote for jsbw-650 not working
Got new one n still dont work
    Top Expert:
  • Jensen Master
  • 74,377 Answers
You should set the remote with the TV, by its brand code. Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Mar 27, 2014
Bought new 650 remote to replace aging 520 which still works. New remote works but ca't get volume to work at same time as changing channels - can only do either or. Q- can I sync the 520 with the new
If it is a universal remote control, set-it up with an other code stated for your device brand. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
Nov 10, 2014 | Logitech Harmony 650 Remote Control
How can i gen my harmony 650 to work with a kogan tv?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
Aug 03, 2014 | Logitech Harmony 650 Remote Control
I have a Sanyo DP42849 TV and the original remote but when I changed the batteries in remote it no longer works. I have tried several new batteries. The lights work on remote but not functioning the...
A lot of the new televisions today come with remotes that have to be re-programmed after the batteries are changed. I would contact the television's manufacture and find out if the re-mote, the television, or both have to be re-programmed.
May 15, 2014 | Televison & Video
How to reset harmony 650 for 'system error!' ?
If your remote is not behaving properly, you can reset it. To do so, remove one of the batteries, hold down the All Off button, and reinsert the battery. A message will appear on the remote screen indicating that the remote has entered safe mode. Next, connect the remote to your computer and sync it. The remote should now be updated and functioning properly.
May 12, 2014 | Logitech Harmony 650 Remote Control
To reprogram my remote for on my Jaguar X-Type does the ignition or the engine get turned on 8 times?
I am going to save you $400 here buddy. First make sure that the battery in you remote is good. Now here is Jaguars big secret, place key in ignition. Turn to position 1, now turn key up to position 2, then turn key back to 1, repeat this 4 times and you will here a ding sound. There you have it your remote is programed to your Jaguar. You must be fluid with it dont go to fast but unless its done perfectly it will not work. The ding sound is what lets you know it has worked. I had a 2002 x-type and when I bought it , it only came with 1 key hub which of course wasnt programed so I took to Jag and thats when they hit me with this crazy amount. They said $150 to test if your remote even works if it does the for another $150 they would program it for you. If your remote is bad though its $150 to test, $150 for a new key hub, and $150 to program it. And FYI we are not talking about a new key oh no. The key splits into 2 pieces $150 only gets you the remote side which is what you need to use yoyr keyless entry and trunk........ Dont ever loose the whole key bro $650 Be aptient until you find your rythem follow the steps exsactly Key in ignition pos 1 then pos 2 and repeat 3 more times giving you a total of 4 cycles through the process once you hear the ding soynd your good. You might have to repeat every once in a while but dont get yourself discouraged if your remote is already programed to you car then the process unprograms it and the process will have to be repeated. It works brother if you do it right. Good luck ;)
Jan 23, 2014 | 2008 Jaguar X-Type 3.0
Logitech harmony 650 remote doesn't work with old Roku player
I have an old Roku and was able to get the harmony 650 to recognise it. The model of my old Roku was SD since I originally used it on my analog TV. Everything seems to work without having to "teach" the Harmony. The only quirk was having to use the Exit button to go back to a Netflix movie description and again to go back to the channel list.
Jan 15, 2012 | Logitech Harmony 650 Remote Control
Dropped the remote and now I can't turn it on!
I dropped my 650 remote last night and it no longer worked - one of my batteries was loose, so I carefully bent one of the battery tabs out - now it works!
Jan 19, 2011 | Logitech Harmony 650 Remote Control
GV-650 12CH PROBLEM
Update your drivers to run on the new OS
if the drivers are unavailable try running the program in Compatibility Mode
Right click on the icon on your desktop or from 'All Programs' - select 'Properties'
Select the Compatibility tab
Select Compatibility Mode
Use the dropbox to show the OS
Click OK
Restart your computer
Jun 03, 2010 | Geovision GV-650 8 Channel Video Capture...
Treo 650 cell phone
buy new battery nimh in ther sit so long loses full charge cant get back .
Feb 05, 2008 | Palm Treo 650 Handheld
Televison & Video Logo
65 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
