Question about Belkin Components - f1dc108h - Belkin F1dc108h 19-inch Widescreen L
Belkin f1dc108h not recognizing servers
Kvm switch doesn't recognize any servers connected to any port
Screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
Belkin Switch Problem
no its not, sometimes that device or the port connection are not installed yet properly. To check it on the device manager, see to it that the connection on your Belkin Switch are functioning. Or try another port or USB connection, it might work there.
Jul 22, 2009 | Belkin F1DK102U 2-port KVM Switch
I am unable to get my computers to recognize my mouse or key board? System is connected to two dell towers.
Do they work fine if you connect the keyboard and mouse directly? Does the video connection work correctly? Check that the appropriate ports are enabled in the BIOS (USB or PS/2).
Jul 19, 2009 | Belkin F1DK102P 2-port KVM Switch
Kvm switch not recognized by one of my computers
Have a close look at the NIC assembly in both the computers.Simply link one computer to the other and see that it detects this or not. Alternatively bypass the switch and try to connect to the broadband from each PC. If u are able to access the net without the switch, then most probably the switch is conked out.Change the switch...................sodeep
Apr 11, 2009 | Belkin 2-Port USB Flip KVM Switch with...
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
My Keyboard only works on one PC but the monitor and mouse works on both?
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Oct 09, 2007 | Belkin F1DK102U 2-port KVM Switch
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Cannot switch between PC's
Typically, the KVM indicator light will only light up on the connection that is currently active. The indicator light will switch to another connection when that connection becomes active. First I would make sure that all the mouse and keyboard connections are secure. I have seen where these sometimes pop out, and thus some componenty will not work. I would then make sure that all the computers are fully powered on. The KVM will not allow you to switch to a device if it is not powered on. The KVM may indicate that a connection is down by a blinking light if you switch to a port and the connection is not up. It sounds that you have atleast one good set of cables. I would confirm that the other sets of cables are good as well. Do this by swapping the other cables with the one port that you know you have working. Finally, with a set of good working cables, swap them over to the other ports on the KVM switch. Although it may be improbable, you may have a bad KVM. AS always, I would review the product manual here: http://web.belkin.com/support/download/files/P74711ea_F1DJ10x_man.pdf And, since this is a new product, you will also be entitled to free tech support from Belkin: http://web.belkin.com/support/phonenumbers.asp?pge=bro 1-800-2BELKIN x2263
Sep 03, 2006 | Belkin (F1DJ104P-B) 4-port KVM Switch
Belkin Components - f1dc108h - Belkin F1dc108h 19-inch Widescreen L Logo
63 people viewed this question
Top Belkin Components Computers & Internet Experts
William Miller
William Miller
David Payne
David Payne
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
