Question about Drills
18volt cordless drill battery charger will not charge batteries
18 volt slide on battery charger to suit epc182 black and decker cordless drill will not charge the batteries where can I get it repaired or replaced
    Master:
  • 340 Answers
Fist you should check that if there is problem with your battery or charger. Do you store your batteries in right way when you don't use them?
You can come here (Power Tool Batteries Drill Batteries Replacement) and find if there is batteries or chargers for you.
Posted on Jun 17, 2014
  • 74 Answers
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Posted on Feb 10, 2009
  • 3 Answers
SOURCE: fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Posted on Aug 27, 2009
VtToolMan
  • 704 Answers
SOURCE: black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
Posted on Sep 12, 2009
  • 8 Answers
SOURCE: charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Posted on Nov 17, 2009
  • 11 Answers
SOURCE: I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Posted on Apr 17, 2010
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
Nov 19, 2011 | Black & Decker 18 Volt Cordless Drill...
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
I have a black and decker firestorm charger/radio 18volt for my cordless tool set. i was just woundering? when i put the balck and decker 18 volt batery in it to charge it has a red light that comes on...
It sound like the battery isn't charging correctly. Check all the battery contacts are clean first and then try and check the charger is ok.
Apr 20, 2017 | Garden
The drill has stopped charging up. No obvious
It may be the charger, but most likely the battery can no longer hold a charge. This may happen if the battery drops below its holding charge. Example, left discharge for a couple months. There is little that can go wrong with a charger unless you start smelling burnt plastic from it.
Jun 07, 2010 | Black & Decker 18 Volt Cordless Drill...
Green light stays on when charging the red light does not come on
The battery is dead, and the charger will not not charge it. You need to purchase a new battery.
Apr 08, 2010 | Black & Decker 18 Volt Cordless Drill...
Have a Fire Storm place battery in charger green light comes meaning full charge but place in drill there is no charge. Is it a new battery, or new charger, or new drill required
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Oct 16, 2009 | Black & Decker 18 Volt Cordless Drill...
Charger not charging have 2 new chargers neither 1 will work for black& decker 18 volt cordless
Mar 08, 2009 | Black & Decker 18 Volt Cordless Drill...
Schematic / service information for Black and Decker VP 130 battery charger
Power supply for the VP130 is a 4.32v 210ma AC transformer.
The AC supply is fed to the charger battery box where there are two diodes one for each battery.
each battery is 3.6 volts.
Jan 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
269 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
