LG WM2277HS error code LE
This is from the service manual for your washer. The hall sensor may be defective but you will need a technician to check out the other things listed here. The sensor is not covered for 7 years. Good luck
Go here to learn how to install ~ http://136.166.4.200/contents/Laundry/WM2432/WM2432xx_Service_Manual.pdf
LE LOCKED MOTOR ERROR
• The connector
(3-pin, male, white) in the MOTOR HARNESS is not connected to the
connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric
contact between the connectors (3-pin, male, white) in the MOTOR
HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is
bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
