Plasma tv troubleshooting
My new panasonic 55vt60 shows one 1mm green blinking dot.what is the problem?shall return it? thanks
  • Televison & ... Master
  • 17,000 Answers
If that dot is on the main screen, it means that there is a dead pixel. Depending on the warranty, this might be something that you have to live with.
Posted on Mar 26, 2014
SOURCE: The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
My plasma tv ONLY show green light for maximum of 2 seconds and off Itself again which means NO PICTURE, NO SOUND !
Posted on Jan 27, 2008
SOURCE: red and green dots
This post is basically for anyone that stumbles across it trying to fix what seems like two fairly common problems with plasma tvs. I apologize for the length of it but hope it can help others.
To start off, I got a free Audiovox FPE4216P 42" Plasma TV.
The previous owner said that there was a red cloud in the top center that after time spread across the top and down the center of the screen. Some time later, they were watching it and it was as if someone simply turned the power off. After that, there was no longer any picture - menu or otherwise.
After much research on the net, it seems that fixing plasma TVs is strongly based on the educational guess method. This compounded by the fact that replacement parts are quite scarce and generally crappy customer service provided by the manufacturer if the TV is older than 14 months basically makes many of these TVs $2000 doorstops if something goes wrong with them. Luckily, my TV uses many LG boards which seem to be used in a number of different makes and models.
NO DISPLAY ISSUE:
Once I took the set apart, I first checked the power coming into it and it checked out ok. I then found a fuse on the YSUS board that had blown, upon replacing it, I no longer had sound. The indicator light on the front would turn from red to blue for about 3 min then back to red. After this happened, the LED on the power board would light up and the there was no longer any response from the power button (led on front would only stay red). I would have to unplug the set and plug it back in to duplicate the above.
I then checked the voltages for Vs, Va and 5v on the connectors coming off the power board (using the DC setting on a voltmeter) against the specs on the sticker on the back of the display panel and they checked out.
It was recommended that I change the YSUS board since the fuse had blown on that board. This seemed counter-intuitive to me since it seemed that the power was fed into the YSUS board through that fuse first as if to protect the YSUS board.
With reluctance, I purchased a "new" YSUS board. Once I popped it in - presto! I had picture! But picture with a cloudy, sparkly red "I" beam that would show through the dark areas of images including the menu screens. It seemed that as long as there was a color over where the "I" beam ran, it was fine and there was only a problem when the image was supposed to be black.
RED DOTS - SPARKLES - SPECKLES - and possibly MAL DISCHARGE ISSUE:
I say possibly mal discharge because it seems that some label this problem as such where some describe mal discharge as another problem.
After much research on the net (again), it seems that there are two fixes for this problem: 1 - a new control board and 2 - adjusting the voltages. It seems that each fix has about a 30 - 50% success rate. With the first fix, you just pop in a new board and you could be done or you could have the same problem. With the second fix, people have said that the dots have gone but the image is now crappy or they have different color dots. Some also say that merely changing voltages will only temporarily fix it. I opted for the cheaper second fix.
My power board has two potentiometers (pots) on it (adjustable dial thingies). One for the Vs and one for the Va. I first made sure that these were adjusted to spec. I took readings off of the molex connector and grounded to the support bracket of the set.
My YSUS board has 4 pots, two are labeled SetUp and SetDn and the other two are on little circuit boards rising off the YSUS board - one of which was completely inaccessible due to it's position behind the support bracket.
I first set the TV to an empty input since the red showed best against all black. Jacking up the SetUp pot seemed to have the effect of making the black really black and essentially removing the red. SetDn didn't seem to due much and I didn't mess with the other pots. When I switched to an active source everything looked great but then I started to notice that on bright images that weren't quite white, there was blotchy pixelation and redness. It then started messing with all three accessible pots and got the image to be really good but I could still see some red and now blue sparkles in the dark areas.
I was pretty satisfied with my results but there was that one other pot that I could not get to unless I removed the YSUS board. Since I knew I would have to adjust that pot multiple times, I decided to remove the board and drill a small hole in the support bracket to gain access to the pot with the board installed. For me, this was the most difficult and frightening part. I didn't want to damage the panel itself and I also didn't want to get metal shavings everywhere. I carefully masked off the area and nearby boards with paper and when I drilled I held a piece of wood behind the bracket.
I then had access to all 4 pots and just kept messing with different balances between them. I used an empty input to check the black and numerous DVD's to look for crappy picture on lighter areas. As it turns out, the menu for the Underdog DVD really showed the light image flaws.
Now, the image is about 98% perfect. When a lighter image turns to complete black, there are some, extremely diffuse red and blue brief pixel flashes (just for a millisecond) but then the black stays black. To notice it, you have to be within 3 or 4 feet of the TV which I think is too close anyway for a 42" TV and is virtually non-existent when watching DVDs.
Here is some extra part number info with possible equivalents:
YSUS: 6871QYH953A or 6870qyh005B and possibly 6871QYH053B EAX31974801 EBR31872801 EBR32642701 6870QYH105B EAX31631001 EBR32642702 1032298-hs
Control Board: 6871qch977b or 6870qch0C6b and possibly 6870qch006b 6871QCH077B 5070-5623
Power Supply Board: 667-PH42FB6-20 or 782-PH42D8-200a and possibly 6FB0192010
Posted on Jun 21, 2008
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
SOURCE: Samsung Plasma TV Model:HP-S5053
I had the same issues and the tech came out and replaced the main board... one way to tedt if it is the PDP is in the service menu.. run the plasam ttests and verify you don't see any dots. After replacement the tech checked all voltages and all is well.
Posted on Mar 28, 2009
I have this problem too. I have had a technician over to service it twice already and I picked up on a few things he did to fix it. Here is what I learned. the raining pixels has to do with the timing in the circuit boards. Basically telling them when to turn on and off. I would only recomend this solution if you are technically inclined. Remove the back from your tv on the left upper quadrant you should see a small gray dial with marks that a Philips screw driver would fit it. There are three or four of these on the boards scatter across the tv. Each on corresponds to the colors firing in sequence. Take your Philips and turn it to either extream. You should see a your screen go crazy with whatever color corresponds to the dial. Then ever so slowly turn the dial undtil you don't see any more flickering. Do that with each dial and you should be able to get rid of most of the flickering. on the right side of the there is a panel underneath the support bar with orange adjuster. I don't know what they do but they also help reduce the flickering. A word of caution. If you can use something non metallic to adjust these dials. There is a small metal lip to keep the dial from turning too far. If your screw driver touches it. It will fry the dial and your screen will blink red/yellow or blue. and you will have to buy a new board. Luckily they are only about 30 bucks, but I learned the hard way.
Posted on Jun 24, 2009
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Plasma tv stop and power light just blinks. Try unplugging and waited to cool down. Still just blinks. Model th-42pz77u
Symptoms and red light blinking 10 times shows that DG board is defective in this tv and it is available HERE for $119
These info will help you to decide about get tv repaired or buy new tv.
Thanks.
May 15, 2011 | Panasonic Televison & Video
Panasonic plasma TV power indicator light keeps blinking, no picture. Does not respond to power on/off switch.
How many blinks is the LED showing? The number of blinks correspond to a service code so that technicians can better diagnose the faulty component inside.
I'm doing factual research for a potential class action lawsuit regarding these "blinking lights of death" problems that the Panasonic plasmas are showing. I'd like to hear more about your experience. It's been a while since you've posted here. Have you contacted Panasonic? If you're willing to share your story with me, please email me at kiaeger@levjen.com.
Oct 04, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
Mar 06, 2010 | Gateway GTW-P42M303 42 in. Plasma...
No picture power button blinks
We cleaned the dust off the fans and TV now works fine. Hardest part was getting the TV down and the back off to get to them. Thanks.
Dec 26, 2009 | Panasonic Televison & Video
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Samsung Plasma 720p HDTV hpt5034
If this is a new set, return it for exchange. This is a warranty repair item.
Dan
Mar 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
