Question about RCA HD52W59 HDTV Projection Television
PC BOARD FOR TV MODEL#HD44LPW62YXI
I HAVE A RCA TV REQUIRED A CIRCUIT BOARD.AFTER 12 MONTHS OF PURCHASING THIS TV IT WENT BLANK HAD IT TESTED AND WAS TOLD IT REQUIRED A PCBOARD
  • 273 Answers
Not sure what board you require . there are several boards in this set and most are no longer available
Posted on May 29, 2014
skippy101
  • 143 Answers
SOURCE: convergance circuit board
you dont need a new board just replace convergence ics that would be the way to go will cost you under 75.00 if you do it your self if you take it in it will cost you 250-350 depending on the shop
Posted on Nov 20, 2007
  • 1694 Answers
SOURCE: rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Posted on May 12, 2008
  • 80 Answers
SOURCE: HDTV MODEL HD52WS9YX39 SERAL NUMBER 6116CNO13
please recheck your model# it should read HD52W59YX39 if this is the correct model the part # is 271850 cost $166.99
changing this part will cause major alignment
the part can be replaced - the RF part # is 215543 for $4.39 or the tuner can be changed part # 268904 cost $30.39
on another note if you are using a cable box or sat box there is no need to repair the rf hooke the tv up with rca plugs
https://www.vancebaldwin.com
thanks
scott
Posted on Jun 09, 2008
  • 61 Answers
SOURCE: Bad Convergence circuit board
rebuilt boards go to shopjimmy.com the have a lot of discontined boards
Posted on Nov 22, 2008
freetek
  • 5568 Answers
SOURCE: need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Posted on Mar 01, 2009
TV screen went blank, can it be repaired?
If audio is OK, the problem is with its back-light. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 03, 2016 | LG 47LG50 47 in. LCD HDTV
Why is my GE front load washer is non responsive. The control panel went blank. Not a power issue since the outet is good. Model GBVH5140HWW
It could still be a plug or wire problem but if not a power problem inside the machine or a printed circuit board or other internal failure. It will not be possible to diagnose the problem without a lot more inforamtion.
Sep 12, 2014 | Washing Machines
RCA Model: RLC3257B just stopped working
I had the same exact problem. The tv had not worked in months. I tested the capacitors by slightly charging them with an ohmmeter and they all tested fine. When I plugged the tv back in, it began working perfectly. It turns out it had been plugged into an outlet that was poorly grounded. I am not sure why the charging of the capacitors rectified the problem but its a cheap fix
Mar 28, 2012 | RCA Televison & Video
Element electronics LCD, was on for several hours picture went blank, sound is still perfect. 12 hours later still no picture when turned on, great sound though.
Typically this failure is due to the backlight inverter going out. On this model of tv there were two runs with different parts. Open the back of the tv and open the control box. If you see a large black circuit board on the top, replace that one. If its tan then you need to take out the control box and remove the black plastic backing. If you're looking at the back of the tv the inverter will be on the left side of the control box. Its a long skinny board that has 8 black metal squares on it. Good luck and be careful.
Mar 14, 2010 | Element Electronics FLX3210 32 in. LCD TV
RCA Convergence problem TV model #R52WM24..parts?
Thats an easy repair. The flyback develops solder carcks which cause the FL231 fuse to blow and weakens DL231 so the set will lose the convergence options under the on screen menu. You can get the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com which contains the components and the CD with repair instructions. Its very inexspensive and includes shipping.
Jan 03, 2010 | RCA HD52W59 HDTV Projection Television
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Viewer on back of camera went blank
I looked though the message board for people with the same camera. Seems there is a consistent problem with the model of cameral that I have.
The response was overwhelming enough to help me make the decision to dispose of the camera.
Jim
Feb 11, 2008 | Cameras
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
