Question about Motorola Mobility HK250 Universal Bluetooth Headset
Hk250 mic doesnt work
Microphone not working, not on mute
Microphone doesn't work on Logitech ClearChat Premium PC headset. I've checked jacks, mute switch. Ran Paretologic to install proper drivers. Is there an on and off switch for the microphone (not the...
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
Mar 19, 2010 | Logitech (980240-0403) Microphone
Turtle beach x1 mic
I found this on the Turtle Beach website:
http://turtlebeach.com/support/index.php?View=entry&EntryID=607418123
This test is to find out if your "Talkback Cable" has failed or the "X1 Mic". It is for the PC only not for the Mac. If it works with the PC but not with the Xbox, then your Mic is good but you need to replace the Talkback Cable.
First, make sure the X1 mic mute switch on the amplifier is turned on. Switch it back
and forth to clear out anything that might have built up on the contacts. If that's
not the problem, then try the X1 mic with your PC to see if the level is OK.
If the X1 does not work on your PC then replacing the 'Puck' will not fix the problem.
Make sure that you do not leave the 'Puck' connected while connecting to PC.
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input)
on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or
Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub)
4) In the soundcard's control software, enable the Microphone for playback.
In the Microphone > Advanced settings, enable the Microphone Boost.
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute
(the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the
mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to
work over Xbox Live, then you need to take a closer look at Dashboard settings and
other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position.
If it is on the ON position the Mic will not work.
Red = Muted
Green = UN-Muted
To find out if the Xbox Controller Cable 'Puck' has failed, you may also try the 'stock'
cable that came with the Xbox. If the original Xbox cable is working, you know you have
a cable that has failed.
Since these cables have to be lightweight so that they do not "weigh you down" while
playing, caution should be exercised not to pull them or get them caught under furniture
etc.
Here is a video showing how to test the mic with your PC in Windows XP:
http://www.youtube.com/watch?v=Vissxo8furo
Jul 07, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
My microphone is not working - says it is working but no sound
Make sure that it is not Muted, Windows comes with Mics muted. If you have a newer Mac most require a powered Mic.
May 26, 2009 | Philips SPC 600NC Webcam
Microphone doesnt work
have you checked the audio properties to see if the mic is muted?
Oct 18, 2008 | Microsoft Windows XP Professional With...
Labtec microphone
try to adjust the line in volume when you double click the volume icon, it may be muted
Jul 24, 2008 | Labtec Microphone Microphone
Ive just bought a headset for my laptop, but the mic doesnt work though the speakers do. My laptop is vista and it doesnt even recognise that there is a microphone plugged in. Any ideas?
please confirm first that you plug mic jack in right socket-open volume control and check mic not in -mute--and fader in up position
Jul 16, 2008 | Audio Players & Recorders
Audio feedback
put your mic on mute for playback. So the mic works but it doesnt play it from the speakers at the same time.
If you dont see microphone on the list click on
options then settings
put a X on the playback -> microphone.
close settings
its now shown in the panel, click on mute and it wont feedback the sounds to you anymore.
May 09, 2008 | Acer Aspire 3000 Notebook
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Why doesn't my mic work ?
which program are you useing?
its possible your mic is on mute so no sound gets throught.
check the speaker icon next to your clock
then press settings and properties and click on regording. then ok. then make sure the microphone is not muted and the sound level is high enought.
Feb 22, 2008 | Logitech USB Desktop Consumer Microphone
New laptop
I had this problem too. My built in mic wasnt working, but i went to the list of programs (Classic view of the start menu) and under the program folder TOSHIBA > Speech System it'll have a choice "Configure Microphone." After I went through that, it worked fine. Make sure you restart your webcam software though after you've done that if you had it open like me. Hope this works!
Jun 07, 2007 | Toshiba (P000257700) Microphone
Motorola Mobility HK250 Universal Bluetooth Headset Logo
42 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
