Question about Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab
Samsung ip adress will not connect
Okay when I go into my setting it tells me that my wifi is turning on and on is on but its like its frozen or something can u help
  • Samsung Master
  • 3,320 Answers
Set up your wifi again but closer to the router.
Posted on Mar 26, 2014
Need mac adress?
The MAC address is a 12-charcter hexadecimal code, grouped in two character clusters separated by colons, that is unique to the device. Some network routers use this as a way to identify devices and validate them on their system. Usually, this can be found in the Settings part of the device, under either Wireless Network or the General Information ("About Tablet") sections.
Nov 09, 2015 | Huawei MediaPad 7 Lite 3G WIFI S7-931u IPS...
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Dec 27, 2014 | Amazon Kindle Wireless Reading Device
My Samsung tablet wll not let me load Facebook newsfeed.I can not log in to Google. It does let me access games
Make sure the wifi/3g is turned on and connected to a network with internet access. You might need to refresh your router and modem as my Galaxy Tab sometimes gets messed up if I log on to another wifi network away from home. i.e. McDonalds/Pizza Hut etc. I may be connected to my wifi, but my tablet doesn't have a correct IP address if it has one at all. The internet speed can be a factor as games don't use a much bandwidth as apps like Google and Facebook.
Jul 27, 2014 | Samsung Galaxy Tab Tablet PC
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
IP Address unavailable/ cannot hook up to internet
Has it been rooted?
The equivelent of a an ipad/iphone jailbreak?
You can check this by doing one of two things.
The first is by going into settings, scrolling down to the bottom and clicking on About Tablet.
If not that then go to Settings/Device and then click About Tablet.
The second, and easiest, is to check to see if you have an app called SuperUser (SU).
If you do then your device is rooted.
Other ways to check, which is more dificult because of you not being able to get WiFi access, is by downloading an app called Root Checker or a Terminal app.
Root checker is self explanitory as it does exactly what it says on the tin.
It will check to see if you have root access to your device and will tell you either way.
The terminal app will show a hash tag symbol (#) as soon as it is started.
This is also an indicator of root access.
Have a look in the WiFi/network settings for your device and see if it has been set up to use a proxy or VPN.
If it has then clear these settings and try to enable the WiFi again.
If this doesn't work then i would restore the device back to factory settings as it could be a software issue.
Failing that you could always upgrade the firmware to the new 4.4 KitKat which, if your device is rooted, will wipe root access out.
Wifi issue
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
Oct 17, 2017 | Lenovo Tablets & eReaders
Sees Wi-Fi but not network intermittently
Seems typical of interference. Have you checked neighbours channels. Lots of apps can search nearby channels. This enables you via the router configuration a free channel. Your signal can say strong but that means nothing. Is your router near a speaker or source of magnet / power. That can cause issues. Any chance you can move the router somewhere else. If this doesn't work then check your phone connection. Splitter change? All wires looking good. Finally you may have a faulty router. It really looks like channel garbage from others as the refusal to sync means the radio channel is damaged.
Apr 01, 2017 | TOMTOP 7" Newsmy NewPad T3 ARM Cortex A8...
Screen reads unable to connect to wi fi network local network connection failed.
Try this and see if this helps. Go into your network settings and press the little blue button to the right to see the network options you should see it already has a dns server and ip adress. Where it says auto join turn this off. Now see if you are able to connect. hope this helps kidromulous
Mar 09, 2011 | Amazon Kindle Wireless Reading Device
My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Jan 02, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab Logo
42 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
