Question about Electrosport 1998-1999 Yamaha Yfm350 Big Bear 4x4 Hunting Atv Plug-in
What do i do if i have gas in my oil?
Replaced needle and seat valve now I smell gas in the oil and I stalls when I reach a higher rpm.
  • 15,628 Answers
You need to change the oil. Gasoline in the oil causes it be to be thinner than it should be and this can cause metal parts to wear faster than normal. Fix the issue with the fuel leaking in first though.
Posted on Mar 26, 2014
18.5 briggs stratton runs a few seconds then starts smokeing then stops smokeing then starts smokeing again
check the oil level see if its overfilled and smalls like gas if so the needle valve in the carb is not seating replace the needle and seat add a **** off to the fuel line and change the oil gas leaks passed the needle valve overfills the carb and drains into the cylinder and crank case run the carb out of gas by shutting off the fuel line and run it til it stalls out every time your done using it
Aug 30, 2012 | Garden
White smoke is coming out of exhaust of husqvarna yth2454
smell the oil and if it smells like gas you have a bad seal on the needle valve in the carb and gas overflows into the crankcase change the needle and seat change the oil and if possible add a fuel shut of valve and close it when not in use
Jun 24, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My craftsman lawn tractor smokes when I start it and it is blowing oil out. What is causing this?
check the oil and see if it smells like gas the needle valves int he carb have had alot of problems seating and gas over flows into the crank case change the needle and seat and change the oil
Jun 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Carburretor floods continuously. Plug Gap ? . Will not start.
the needle valve in the carb is not seating replace the needle and seat check the oil if it has a gas smell change the oil as well
Jun 22, 2012 | Garden
Oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
May 24, 2012 | Yard Machines Garden
Oil leaks out air filter box
smell the oil if it smells like gas the needle valve in the carb is not seating and the gas overflows from the carb into the crankcase
May 24, 2012 | Toro Garden
White smoke
smell the oil and see if it smells like gas the needle valves don't seat and gas overflows into the crankcase if so change the needle and seat and change the oil run it without a load and the change the oil a second time
May 11, 2012 | Briggs Stratton IC Horizontal OHV Engine ...
Oil blows out of exhaust while engine is runing
check the oil to see if it smells like gas if so change the needle and seat and change the oil if its a over head valve engine and the oil smells gas free check the head gasket
May 01, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
LT 1000 flooding gas out muffler and stalls, then pours in carb.
Check your oil. Does it smell like gas? If so, don't run it even if you could. You will fry your engine. The float needle and seat in the carb are leaking. In other words, the float needle is not shutting off the gas when the bowl is full. You need to have them replaced.
Jun 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electrosport 1998-1999 Yamaha Yfm350 Big Bear 4x4 Hunting Atv Plug-in Logo
266 people viewed this question
Top Electrosport Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrosport Electrical Supply Expert? Answer questions, earn points and help others
