Question about Coffee Makers & Espresso Machines
Need new drip tray assembly
Need new one lost part
    Habit-Forming:
    Scholar:
  • 60 Answers
Contact the manufacturer. They often sell replacement parts or post on craigslist and or kijiji &c.
Posted on Mar 26, 2014
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Jun 13, 2014 | Kenmore Side by Side Refrigerator
I have a Miehl cva4070. My problem is twofold. 1. The unit seems to have lost its ability to recognize that the Drip Tray has been emptied. I have turned it off and back on, unplugged and restarted,...
take a long fingernail file that is a fine grit. hold it with a pair of needlenose pliers, and use it to clean the contacts in the back of the machine where the drip tray plugs in. You need to clean each contact top and bottom. you can tape the fingernail file to a ruler or pencil or whatever you need to so that you can reach the contacts. it is very tight as the opening is only an inch or so tall. dont go crazy with the file, just lightly touch each contact. also you can swap the two metal contacts on the drip tray. you will notice that they have little wear lines on them that are in different locations. if you swap them , they will be exposed to new surface. if that doesnt work, you may have an internal leak that is shorting the drip tray contacts from the back of the machine. If there is water back there, it is the same as the drip tray being full.
Apr 22, 2011 | Miele Coffee System
Do you know where I can get some thane barbeque grill drip pans for model nm.qbbq2003 ?
I have 3 BRAND NEW packages of the drip trays! By the time they arrived, the grill had died and I gave up on getting help! If you contact me through Facebook, maybe we can come up with a way to get them to you if you still need them...
Feb 28, 2011 | Thane Q-BBQ Grill
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
Empty Drip Tray message
Try to clip off the tray contacts and clean behind them. If they are dirty and wet on the backside the machine will keep asking you for Empty tray. Use a small screwdriver and clip them off from the inside of the tray
Aug 17, 2009 | Franke Saphira Espresso & Coffee Maker
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Does anyone know a simple way of replacing the drip tray? When I removed the back the drip pan was half under the fan assembly and then wrapped around behind the compressor with some of the coil line
I agree. I have been repairing appliances for 25 years and heve never replaced the style you have. I would be a pretty difficult job. Because of its function, if the caulk is holding you should be ok. I just looked up your drain pan, the Part # is 12477402. It looks like the refrigerator would need to be tipped up and the frame for the compressor and condencor would need to be taken down.
I hope I have helped a little.
Vic
May 08, 2009 | Refrigerators
DRIP TRAY
Please try these numbers or website, hopefully they can help!
CUSTOMER SERVICE NUMBERS
In the U.S. 1-800-851-8900
In Canada 1-800-267-2826
Web site address: www.hamiltonbeach.com or
www.proctorsilex.com
Jan 10, 2008 | Hamilton Beach 25265 Indoor Grill
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
