Question about Microwave Ovens
Arched from recessed area next to light
AREA IS NOW BLACK,LIKE A BLOWN OUTLET.IS IT SAFE TO CONTINUE TO USE? STILL WORKS
  • Microwave Ovens Master
  • 15,557 Answers
Your description is a little vague. I am assuming that you are saying that the inside of the unit has black scorching marks near the area that the interior light bulb is housed. If that is the case then the coating on the inside of the microware is compromised. This is usually caused from food particles getting stuck the inside or it has become scratched. When this happens, the microwave will continue to spark in that area, This will result in further black marks and it will cause the entire unit to fail at its most expensive part, sooner. You can take care of this issue by cleaning the interior very well and then paint the inside again with microwave oven paint. It has to be special paint.
Posted on Mar 26, 2014
I have a Sharp Carousel model R-1874-T. It suddenly stopped working. No lights are on. I checked the outlet and there is power coming there. Is there a way to reset the microwave?
Steve,
You probably have a blown fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 27, 2015 | Sharp Microwave Ovens
Tip
What to do when the microwave is arching.
Hi.
If your microwave cavity is crossed by luminous discharges of current , and you see flashing arches of current from the magnetron area to other areas of the microwave oven cavity, then we commonly say that the microwave is arching.
The first thing to do in this case is disconnecting power immediately, and trying to remove the cause of arching if possible.
Arching will damage the microwave oven, if it goes on for enough time.
Any metal conductive object, such as a spoon or a fork will cause arching if left inside the oven when the microwave device (the magnetron) is operating.
Ensure that there is no metal object inside, while the appliance is operating.
Some vegetable with an high amount of metal , and some other ingredient, like bacon , are known to cause arching in sporadic cases.
In that case add a little water to the food in the oven and try again.
Sometimes recycled paper, or use of containers that are not for microwave can also cause arching. In that case use a different container, or paper.
If there is arching and bad burnt-plastic-like smell with any food being cooked, that means that there is a major problem, and that if the oven is used in this condition, you may get further damage to the appliance. In some case there may also be safety concerns.
As said, you get arching inside microwave when inside the cavity there is a strongly conductive object, such as a metal object or carbon residue.
You also get arching when the oven cavity is damaged.
In this last case the cavity may have lost insulation, and it is better having the oven repaired by a technician, that will also conduct a radiation leak test on the appliance to prove its safety.
To attempt fixing the problem by yourself , you can do the following:
Disconnect power cord.
Check inside the oven cavity, ensure that there is no foreign object inside (such as a small screw). Check also under the turntable.
Check that the light and the magnetron covers are well in place.
Clean the cavity thoroughly, clean also the lamp enclosure if this can be accessed. Carbon residue from food may be causing the arching.
If after cleaning the arching is still there, that means that the cavity is damaged. In that case better calling a technician.
A damaged microwave may loose insulation , and this may be very dangerous for health.
If you want to contact a technician, the best thing to do is ringing the phone number listed on the appliance owners manual.
Ginko.
on Feb 06, 2010 | Microwave Ovens
Light doesn't go off and microwave doesn't work
follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 14, 2013 | Sharp R305KS Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Completely dead; has good power source and fuse ok
Where the door closes there is a a switch you have to take off the cover (plug out device) one of these switchs are probably burnt out
Sep 23, 2009 | Panasonic NN-S541 Microwave Oven
Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
May 15, 2009 | Maytag MMV4205 Microwave Oven
Interior cardboard/foil piece fell off revealing small chamber inside oven--still safe?
This is the mica or plastic waveguide cover. It protects the waveguide and magnetron form grease and food particles.
Assuming you're going to scrap the unit, carefully clean the area around the outside of opening (watch for sharp edges) with a lightly damp soft cloth.
Then use alcohol or a hair dryer, etc. to be sure the area is dry.
Then you can use a couple of strips of clear packing tape to cover the opening and trim it with a razor blade so only about 1/4" or so extends out from the opening.
Note that I only recommend this procedure on an oven that is going to be scrapped. If the oven will see continued use, a new waveguide cover should be purchased.
Oct 22, 2008 | Microwave Ovens
GE Spacemaker Microwave Oven JVM1330BW200
all...you should first check to make sure the outlet you're using is good. Really. Next, check internal fuse and thermosafety in the unit. They are both found inside the button area. The safety is about the size of a dime and 3/8 inch thick with two wires. Sometimes they open. They should be continuous. Not it? Let me know.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating the food
sam..vane...two different problems.
Sam...find out if you've got power in the outlet you're using. If not, you've got to check to see if you've got a blown fuse in the unit. Also ...see below.
vane...chances are you have a power issue or the thermosensor which is used for a safety has blown. It is the size of a dime and 3/8 inch thick...black...two wires. You'll probably find it has opened. Found attached inside the control area to the side of the microwave heating area.
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
