Question about Intel D101GGC Motherboard
My ethernet port is not working. I can't understand what is the problem.I m badly in need of a solution.what do i do???? My motherboard is intel D101GGC model.give me a advice as soon as possible
    Scholar:
  • 74 Answers
In additon to checking the status of the ethernet port in the BIOS setup, it's always a good idea to make sure you have ethernet drivers installed, if you do, than perhaps getting the latest drivers for your main board ethernet would be a good idea.
Posted on Jun 24, 2009
    Problem Solver:
  • 7 Answers
Check wheather the ethernet is enabled in BIOS unless You must have to change the IC related to Ethernet.
Posted on Jun 15, 2009
Hp Pavillion Desktop Modem S/N MXU0112JC Ethernet broken port
you need to get a new board sorry to hear that or you can get a pci to ethernet card or usb plugin cheap 2 dollars
Mar 15, 2014 | EliteGroup ECS G31T-M Motherboard - Quad...
Why my motherbord have no intrnet conection i thought it was a plug and play
Most modern mother boards come with an ethernet port, however if yours does not have one included, you may need to buy a PCI expansion card with an ethernet port included. If you are not able to run an ethernet cable to your computer you can get a PCI expansion card with a wi-fi receiver build into it.
May 01, 2011 | Intel Motherboard
I have a HP pavilion m8020n with Vista OS. I have internet for a while now and suddenly internet just went out. i talked to my internet carrier and we troubleshoot the connections. they said it might be...
2008 PC, shows it has modem too, a dial up. so 3 ways internet.
\there are 2 ways on to the internet (Ethernet and wifi)
aka, wired and wireless, respectively.
sure wifi router works,too, and is more difficult to setup. (im not going there)
try a new cable
try another router port yet, try cycling power only to the router?
sounds like your vista drivers are messed up ,
if another PC works , with ETHERNET cable to router there.then the router is working, test 1, passes.
that means this PC is failing
the PC has a control panel and device manager
see that and the network part? (not wifi , the wired network chip)]
vista 32b or vista 64bit?
your PC came with intel old
  • Interface: Integrated into motherboard
  • Technology: Intel 82562V
  • Data transfer speeds: up to 10/100Mb/s
  • Transmission standards:10-Base-T Ethernet
the driver is?
Intel 82562V
to make that chip work,
intel has it. 6 th down this list, Vista
https://downloadcenter.intel.com/product/76951/Intel-82562-Fast-Ethernet-Controller
load this driver. fixed. (from a working PC on the net)
then move it to dead pc and load it.
you are plugged in to X here. right.
or is there a card plugged in on the right, with RJ45 ethernet jack.
yes, you sure can add a new Ethernet card if the X jack blows out.
p5lple-fvyief5l4kybalhvncmspljg-3-0.jpg my DM ethernet port, im tying through it now...
mines a w10 gigalan port. so... is not intel like yours. ignore Realtek name pretend it says, Intel 82562V
May 23, 2017 | HP Pavilion m8020n PC Desktop
My lan driver not work
Go to the following link, select your operating system then download it & install. http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%C2%AE+865+Chipset+Family
After installing, right click on My computer, Hardware, Device manager. Check Any thing in yellow color in Network adapters or in any place. If it is related to network then, re-install Operating system & try. If nothing is in yellow color then the Ethernet port i.e., LAN port is gone bad replace the same & insert new LAN port in other slot i.e., PCI slot & install the driver & check. I hope it will work for you.
Jan 24, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I need Ethernet driver for Intel D945GCCR..
You can download all the drivers that corresponds to your motherboard from the folowing link
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCCR
You have all the drivers, choose the ethernet driver and install it to make your ethernet card to work.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Nov 28, 2010 | Intel D945GCCR Motherboard
Ethernet ports are not working in my intel desktop board D101GGc.
You will need to supply more information here. Example, open your Network Connections from the Control Panel. You should see a LAN icon. Is it enabled? Does it say "network cable unplugged" even though it's plugged in?
Sep 03, 2010 | Intel D101GGC Motherboard
Need a driver..
Here you have specs for that motherboard:
Part/Feature Support/Specification Motherboard Description
  • Manufacturer's name - N1996
  • HP/Compaq name - Argon
Motherboard Supplier MSI System BIOS Supplier MSI/Award Form Factor uATX Processor Brand Intel Maximum approved processor 2.53 GHz Intel Pentium 4 Processor Socket Type mPGA478 Processor Family Intel P4 or Celeron Processor Front Side Bus Frequency 400/533MHz Chipset Name 845E Chipset "North Bridge"
revision/stepping 845E
A1 Chipset "South Bridge"
revision/stepping ICH4
A1 Super I/O
revision/stepping Winbond
W83627HF-AW Flash BIOS Device 4MB Flash EEPROM Memory Type 2.5v. DDR Memory Speed PC2100/PC1600 Memory Sockets 2 DIMM Maximum Memory 1GB Graphics Supplier Intel Graphics Configuration Up Graphics Connector (AGP) AGP 4x TV-Out Device No Audio AC'97 Down AC'97 CODEC Device Realtek ALC202A Audio Jacks (legend below)
M Microphone M,LI,LO,SO
LI Line In
LO Line out
SO Speaker Ethernet 10/100 LAN Supplier Realtek RTL8101L Ethernet Configuration PCI Down IDE UDMA Modes ATA-66/100 Expansion Slots (AGP/PCI/Exten) 3 PCI USB Ports 6 USB Front/Back Options 2F+4B Serial, Parallel, Floppy, PS2 Kbd and Mouse 1S,1P,1F,PS2 K+M Serial Port Front Chassis Option No Available Mfg Options -U,L,A,S
A Audio down on motherboard C External L2 cache on motherboard E 1394 on motherboard G Graphics down (on motherboard or in chipset) L LAN on motherboard (Ethernet) P - PCMCIA slot S S3 power management support T TV-out on motherboard U Graphics card (up, not on motherboard) W Microsoft®) Windows XP hardware compliant
Nov 19, 2009 | Computers & Internet
Compatible board for P-4
ok so its a 478 socket
best board available is an asrock P4I65g
Specification Value Product Description ASRock P4I65G - motherboard - micro ATX - i865G Product Type Motherboard Form Factor Micro ATX Dimensions (WxDxH) 24.4 cm x 19.8 cm Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz Processor 0 ( 1 ) - Socket 478 Compatible Processors Pentium 4, Celeron D RAM 0 MB (installed) / 2 GB (max) Supported RAM Technology DDR SDRAM Storage Controller ATA-100, Serial ATA-150 USB Ports Configuration 4 x USB Storage Ports Configuration 2 x ATA, 2 x SATA Graphics Controller Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0 Audio Output Sound card - 5.1 channel surround Networking Network adapter - Realtek RTL8101L - Ethernet, Fast EthernetView extended Specifications
Oct 18, 2008 | Intel D865GBF Motherboard
Ethernet
dear ashprabha,
you are saying that your motherboard doesn't have a on board Ethernet slot. now, if u want to connect to internet means
then you have to purchase and fix a PCI Ethernet card. so that you can connect to internet.
Sep 26, 2008 | Intel Motherboard
Intel D101GGC Motherboard Logo
1,154 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
