Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Eidw6105gb1 dishwasher lights blinking took toe plate off the wash pump light is on but the unit washes great cound that control be sensing a but wash pump even if the pump is working?
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon John,
I see that your Electrolux dishwasher, model# EIDW6105GB1, has all the lights blinking and is revealing the wash pump light. This could just be a false error and would need to be cleared or it could mean that the wash pump is going bad. You can try resetting the appliance, by cutting the power at the circuit breaker for 20-30 minutes. When power is returned, start a cycle. If the lights are still flashing and revealing the wash pump light, I suggest either contacting the manufacturer or maybe a local authorized dealer. Hope this helps.
-Best of luck-
WP
Posted on Mar 27, 2014
SOURCE: Dishlex dishwasher
I have the same problem and the main conrol board was replaced. No Problems since.
Posted on Jun 11, 2007
SOURCE: dishwashing machine whirlpool electronic control ADP 4520
Check the Water Indicator (WI).
When you think it should be enough water, unplug WI connector from control board and check if on WI connector is closed contact (WI written on the control board housing). If not, try with some more water. And so on. When too much water with no contact on WI, it is the one to be replaced by new one.
NOTE: by every check UNPLUG the machine
Posted on Feb 18, 2010
SOURCE: I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
Posted on May 30, 2010
heatman101
  • 43501 Answers
SOURCE: my dishwasher has started to leave a film on the
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Posted on Oct 07, 2010
caroldon
  • 17130 Answers
SOURCE: Hi i have a Electrolux
This can be a possible fault with the program controller unit. You will need to observe and make some tests as the washer works and stops. So check with all precaution if you are able to use a multimeter.
check the voltage on the motor while agitating. now does it cut off - if so the program controller is faulty , However If the voltage stays but the motor stops then the motor is faulty , the capacitor reduced in value or the mechanical section of the agitator/shaft can be jammed.
Check the program controller, check all connections , remove clean and set. check the door switch.
Posted on Feb 19, 2011
MODEL DWF31 START PROGRAMME DISPLAY SHOWS 2H AND STAYS ON 2H ANY IDEAS
Hello. First, try to reset the control board. There are 2 buttons with arrows underneath. Press and hold them both for several seconds, maybe a little longer--this will perform a reset on the control board. See if that clears up the problem. Also, are there any lights blinking? Dishwashers will flash error codes(in binary format) by blinking certain lights in a pattern(i.e. The "sensing" light will blink 2 or 3 times, then the "cycle complete" light will blink 2-3-4 times--something like that) It could be any combination of lights depending on the component that has failed or has a problem. Components can be the drain pump, main wash motor, float switch(if present), heater circuit, inlet water valve, flood switch(if present), etc...
Sep 26, 2015 | Hotpoint Dishwashers
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
Clean Light blinks, wash cycle does not initiate
The clean light usually will blink due to a failure to heat the water properly. I have put together some information on this and how to reset the machine so it will work again. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 06, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Water in Machine-Lights Blinking
Hi
Thanks for using FixYa. That means the control sensed that the heater in the D/W did not operate 3 times in a row. So the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. Use a meter to see if it reads open; if so orders a heater assay it will come with a new control replace it too. If heater checks good then press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec and all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water and incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this ensures your unit fills with hot water and not cold
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
DisHWASHER WAS blinking and tried to restart and now it will not start, checked the breaker what else can I do
Hi
Thanks
Rylee
Nov 21, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Washing light blinking-will not work
Door switch? The unit might not be able to sense that the door is closed.
Mar 09, 2008 | Kenmore 24 in. 16259 / 16254 / 16252...
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
202 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
