Question about Power Equipment Solutions 2002 Club Car DS Street Ready 48V Golf Cart w/Jeep Wrangler Body
Club car golf cart won't charge tripping 15amp breaker on charger
Golf cart not charging
  • 24 Answers
If you haven't fooled with any wiring, make sure the wires at the cart charging connector are tight and not touching. The circuit breaker on the charger can also fail, but I agree that the diodes would be the first place to look.
Posted on Nov 26, 2014
  • 637 Answers
Check the diodes. There are a lot of You tube Videos.
Posted on Jun 19, 2014
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
How do you check output voltage from generator to battery in an club car golf cart
if you look at the charger plug there is a small switch it can either be held down with the cover off or with it on. It should read you between 48 and 50 volts DC with that switch in that switch will keep you from charging the batteries if it is faulty. These chargers are really rather simple and golf cart King has the motherboards cheaper than anywhere else that you can buy them. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 31, 2014 | Golf
48v club car wiring diagram
Make sure all wires have continuity from one end to another.
Apr 15, 2014 | Golf
Club cart wont go have to push
Need more information. Year, electric or gas??? If electric, does meter on charger indicate charging??
Mar 16, 2014 | 3d Rose Londons Times Funny Cow Cartoons -...
MY 1993 CLUB CAR GOLF CART WILL NOT MOVE, I HEARD A LOUD POP WHEN I WENT FROM FORWARD TO REVERSE/ANY SUGGESTIONS?
check to see if there is a circuit breaker on the wire path from your batteries. Could have blown the motor but You would see some smoke more than likely, and smell it burning. What you described with the popping sounds like an electrical short where the wires just burned up but again you'd smell it and maybe see smoke. The switch may be bad also check it with a meter to see it its making contact and see if voltage is coming up to and exiting the switch.
Aug 06, 2013 | Dual Club Car Lester Power Drive Charger...
Troubleshooting charging system on a gas club car
Measure your battery voltage. Then measure your battery while cart engine is running. If you get 2 or 3 volts higher while engine running than when it's not, your charging system is ok. Lets say your voltmeter measures about the same voltage either way. Remove the small yellow wire on the starter/ generator and insulate. Place a jumper between the post that the yellow wire was on and the negative post of the battery. Now measure the battery while the engine is running. If you now measure higher voltage then your voltage regulator is bad, if you don't measure higher voltage then your starter/gen is bad.
Jan 25, 2012 | Golf
Power Equipment Solutions 2002 Club Car DS Street Ready 48V Golf Cart w/Jeep Wrangler Body Logo
642 people viewed this question
Top Power Equipment Solutions Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Power Equipment Solutions Golf Expert? Answer questions, earn points and help others
