Question about Mitsubishi WD-60638 DLP TV
Replaced lamp. Powered up TV,, after 6 minutes picture started to blink. Cleaned dust out of the two muffin fans that were visible. I also cleaned the cooling fins aft the smaller of the two fans. Pow
I suspect that there isa problem with keeping the lamp cool during operation. I hear and feel faint airflow but can't really tell if the fans are running at full capacity. can the muffin fans be purchased a normal computer shop?
    Scholar:
  • 195 Answers
If you get one that has the correct airflow and RPM along with the proper voltage and such, but I would try on Ebay first.
Posted on May 08, 2014
Slinteriors
  • 8617 Answers
SOURCE: no picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 26, 2009
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Posted on Sep 09, 2008
  • 927 Answers
SOURCE: Replaced Lamp & yellow light indicator blinking. Still no picture
Good Day;
1. Check for an open AC fuse F9D00, if open check for a short on the 340v line to the lamp ballast between pin 1 an 5 at connector PL on the Power PCB, if shorted replace PWB-POWER LAMP (Ballast) part # 939P978010 and F9D00 part # 283D131040 2. Check for open AC fuse F9D00 part # 283D131040, if open check for proper seating of connector K1 on the Power PCB
Dead unit wd52525 mits
NO POWER
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Posted on Oct 10, 2008
SOURCE: mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Posted on Nov 11, 2008
  • 179 Answers
SOURCE: tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Posted on Dec 29, 2008
My ws-65615 tv blinks AND GOES BLACK
It may indicate the lamp needs replaced, or that the cooling fans are not turning. When the controller senses too much lamp current, or dimmer than minimum light output, the controller will shut down the lamp to prevent damage. Replacing the lamp fixes that. Over-heating, or fans not rotating will cause the controller to shut OFF the TV. Clean and lubricate the fans with a vacuum and a tiny drop of lubricant on each motor bearing. Also clean and vacuum the air filters. Dust and dirt are the enemies of fans and lamps. Regards.
Aug 13, 2015 | Mitsubishi WD Televison & Video
Sony KDS R60XBR1 red light blinking 3 times. Replaced lamp, cleaned all vents, replaced cover door properly.. What else?
You may need to take off the back cover and clean the fan and if you can, put a little oil on the fan shaft. I also use a small vacuum to get more of the dust out around the fan. You can blow out some of the dust but be careful as you don't want to blow dust into the lamp area. When you take off the back cover you'll be amazed at the amount of dust in there!
Feb 12, 2015 | Sony Televison & Video
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through dlplamps.com
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
Sony KF-50WE610 Tv won't turn on, red light blinks 6 times
3 times means Lamp and 6 means you have lost a voltage. You may have a thermal fuse blown.
This set has a common trouble with overheating caused by the drum fan located on top of the lamp housing clogged up with dust. When the lamp is getting old it runs hotter and that combined with the fan being clogged the thermal fuse blows. You must replace the lamp and thermal fuse. You must also clean out or replace the lamp fan. This drum type fan should be cleaned out every year or two depending on the environment.
Apr 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
4 blinking red lights in power/standby
I would recommend replacing the fan, cleaning it doesn't solve the problem...If it does, it's only a temporary fix. Replacement fan is around $30 and easy enough to do yourself...
Sep 15, 2008 | Sony KDS-R50XBR1 50" HDTV
Replaced lamp and still no picture.
Does the red indicator flash or blink? How many times it blinks is a error code that tells a liitle about what is wrong. For instance, 3 red blinks means the air filter for the cooling fan is restricted and needs to be cleaned.
This model has lots of complaints against it, get it working and then put it under an extended warranty.
Hope Ya Fix it!
Jan 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Regarding problem in sony tv model no. kdf-e60a20
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Oct 06, 2007 | Sony KDF-E55A20 55 in. LCD Television
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mitsubishi WD-60638 DLP TV Logo
169 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
