Question about Honeywell R7284U1004 universal electronic digital oil primary
No LED display on Honeywell R7284u1004
I have domestic hot water working on Carlin Oil-fired boiler, but no heat. When I press the "i" button there is no LED display. Boiler PSI is just below 30, so no low water level issue. I can't get the oil primary to work for "call for heat,"
5 Suggested Answers
  • 234 Answers
SOURCE: what would the correct high and lo and diff
I would say high if you need cooling. If the tempature is cool enough for you then set it to low.If you are hot and need more cooling then high.
Posted on Apr 07, 2009
  • 148 Answers
SOURCE: Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
Posted on May 10, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: what is the recomented settings for high and low
180 with a differential of 15 or 20. So 180 high and 160-165 on low.
Posted on Nov 03, 2009
Testimonial: "Thanks"
  • 2463 Answers
SOURCE: Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Posted on Feb 18, 2010
My boiler dosent come on i have no hot water but when i turn the heating on boiler works but still no hot water what should i do
Hot water is gravity fed through your pipes. When you turn the faucet on the water will flow through the pipes. If your hot water heater is natural gas driven relight the pilot. Same if oil fueled. If electrical, check fuse to see if it has blown or the circuit breaker has tripped. If either has tripped, replace it and if it blows again the heater has a serious failure, you might need to buy a new one. If pilot won't light on gas unit, try relighting after 5 minutes, could be a bad thermocouple.
Apr 03, 2015 | Water Water Heaters
Need wire diagram from the hot wires feeding a blue angel oil burner and blower motor
Dean,
What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
I have a boiler ( hot water heat) oil fired. Can I convert this boiler to propane?
Hello YES! They have power conversion burners for that.Make sure you ask for a L.P. conversion kit as some can ship already set up for natural gas.Try CARLIN.com
Sep 12, 2010 | Heating & Cooling
May 08, 2009 | Honeywell Programmable Thermostat Heater
Vaillant Ecotec combi boiler - radiators working but no hot water flow to taps
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Oct 05, 2008 | Heating & Cooling
Have an oil fired boiler for baseboard heat and it also has a tankless heater for domestic hot water. No heat being called for only getting hot water for use. Boiler goes to 210 degrees before it knocks...
These boilers usually have multiple controls. The control that would take it out of the circuit at 210 degrees is a safety.
You should definitely have a professional take a look at this unit before you continue using it.
Sep 18, 2008 | Heating & Cooling
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Honeywell R7284U1004 universal electronic digital oil primary Logo
Top Honeywell Televison & Video Experts
Ron Durham
Tom Chichester
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
