Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge Freezer E402B not functioning properly.Solid red error light,with green light flashing up and dwn when push the = button.No air circulation to fridge,compressor seems to continious,also fridge
AS MENTIONED IN SUMMARY
    Master:
  • 966 Answers
Natasha try this:
turn off the fridge's settings.
pull the power cord from the wall outlet
open the doors and keep them so for a few hours.
before these, take out the most perishable and keep in cool place.
after a few hours you may see a puddle of water under the fridge. clean the water and vaccum the fridge underneath and behind.
now reconnect power and set at recommended level. goodluck!
Posted on Mar 26, 2014
Testimonial: "Thanks.This error has now been fixed.It was the wiring in behind the control panel.One of the connectors had come loose.But now a new problem has come about since then.Fridge went back to normal for around two hours.Compressor coming on,fans all go,all lights go.Temp lcd display normal.Opened the fridge couple hours later and it had no power.Compressor off.No life to the fridge????????I tried plugging in the vacuum at wall outlet and it went fine.But i did notice that the outlet exterior was quite warm...any suggestions on this prob?"
Chef Base is cool but not cold enough and way to adjust this..
  • Check the thermostat control. Even if you've not touched it, something may have knocked it and adjusted the setting. The thermostat may also need to be adjusted depending on the temperature of its surroundings and the coldness of the weather.
  • Make sure any food stored in the fridge or freezer is not blocking any air vents. This can stop air circulating properly.
  • If the fridge is too close to the wall, the condenser coils will not function properly.
  • Defrost the fridge and freezer thoroughly and clean the inside surfaces with warm water. Check any air vents to ensure they are not blocked.
  • Clean the condenser coils at the back of the fridge using a vacuum cleaner, making sure all dust and any dirt are removed. Clean any stubborn dirt away with warm soapy water, being careful not to scrape the coils. Turn your fridge off and unplug it before doing this.
  • Make sure the fridge's fans are not clogged and are able to function properly. Again, you need to turn your fridge off and uplug it before attempting this.
  • Check the door is closing properly. Make sure nothing is obstructing it or pushing it slightly open. Ensure the seals around the edge are working well.
Jun 03, 2015 | Refrigerators
Fridge not cold. Compress or runs 5/10 seconds smoothly then kick s out . DW
Jun 02, 2015 | Refrigerators
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
HI, I have a Fisher and Paykel E402B fridge the fridge nor the freezer get anywhere near cold enough and the warning light at the back of the fridge has just started flashing Continuously and every couple...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
The red light remains on...
The coils should have a nice white frost pattern evenly on the coils (no solid ice block sort of thing). If there is very little frost, or say just chunk of ice in one spot, then you may have a leak in the system where the refrigerant has leaked out. The fan above the coils should be on when the compressor is running to circulate the cold air. It does sound like you may have a sealed system leak and there's just not enough refrigerant to flash into a gas for proper cooling. Check on these items and get back to us.
Jan 13, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Jan 12, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
257 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
