Question about Sharp Zaurus SL-5000 battery 900 mAh
When I try to engage my pc and transfer info, it say I lost my port comm. What does that mean?
PC link ready,bot cannot find the port comm and says it's being use by my mouse or something else and that's not true.
The internet connection to my thermastat was lost how do i restore my connection?
am I readying this right, connection to your thermastat???
what do you mean by thermastat? or do you mean thermostat?
if it is I still need more info please.
Nov 04, 2016 | Internet Computers & Internet
Fujitsu scanner with paper port says scanner is out of memory close other applications
try the scanner with another pc cos it may be ur pc dat get d problem,the problem means it been used by another programme o r u try to restart u pc and try it back or at time if u didnt install the d river complete it may arrive to dis problem bot what normally cause it is pc
Apr 09, 2012 | Office Equipment & Supplies
Cant transfer photos from camera connecting as instructed in book bot nothing happens
To transfer Pictures to PC only connect to PC using USB Cable.
If don`t work try the following
1.- Go to control panel -- Device manager
check if they are a yellow mark near the device
if have a yellow mark, select -- right click --Uninstall
2.- restart your PC and check if work
If trouble continue
1.- Try connect to other USB port
2.- Connect to another PC
3.- Try with other cable
You can buy USB Cable on
http://www.ebay.com/itm/USB-Cable-U-8-Kodak-Easyshare-C310-C330-C340-C360-/140526859630?pt=Camera_Cables_Cords&hash=item20b80db56e
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Kodak EasyShare C340 Digital Camera
Sharp zaurus zr-5000 stopped working. Any way to get my backup flashcard (FL02M-20-11138-XX 15095) to read to anything?
I have lost all comm ports for exchanging info to and from my Zaurus 5000. It says my ports are being used by my mouse which is not true.
Anyone have any ideas on how to retrieve ports?
Ted
Oct 20, 2010 | Sharp Zaurus ZR-5700
Cannot transfer tape contents to PC
To transfer video from your camera you will need a firewire cable and a firewire port on your PC. If you don't have such a port you can buy a PCI firewire port.
After you connected your camera with firewire cable you can then use windows movie maker to transfer your video.
See this for more info and photos
Feb 28, 2010 | Panasonic NV-GS400 Camcorder
Connecting my phone to my PC
Nettworking wizard will be opened after you are able to connect the phone. For that you must start PC Studio and select Connect. There you will fine various means to connect. Select USB and connect. Or BT connect. Then select a comm port one by one and try to connect. One of the comm ports will accept the phone and connec.
Aug 22, 2009 | Samsung SGH-U600
I net connect two PC using comm port and transfer data b/w them
communication ports are very difficulkt to connect, so i suggest you lay your complain to google website and search for the details of installing it
Dec 07, 2008 | Computers & Internet
Disabling COMM ports
If you're pretty sure its your comm ports, boot up into your bios setup screen. (Tap Del while booting) Then go to the onboard devices page or any page that lists your com ports and change the property value to disabled.
Regards,
Worldvet
Jun 19, 2008 | EliteGroup K7VZA Motherboard
How to transfer info to another computer with datatraveler100
plug the datatraveler100 into One of your Usb ports, wait for it to be ready to use, then got to the data yo want to transfer right click on it then choose an option of send to then click on the datatraveler100 so data will be copied there.
then unplug it plug it in the other machine
go to my computer open removable disk (datatraveler100)
then you can see your data you can choose to copy and paste it anywhere in your computer.
hope this works for you.
Jun 18, 2008 | Computers & Internet
Aligning ports
There is no in built driver for USB to COM in windows. You need third party driver/software to do so. If you have any device with COM port interface that device might be shipped with supporting driver, please checkout.
If you don't have, You should try this link:
Thanks
Iqbal
Mar 18, 2008 | Compaq Presario 700 470024-192 Notebook
Sharp Zaurus SL-5000 battery 900 mAh Logo
22 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
