Question about Samsung Digimax S500 Digital Camera
VERY HIGH BATTERY COSUMPTION
THERE IS A VERY HIGH BATTERY COSUMPTION
WHY?
  • 77 Answers
The solution is simple - Use Lithium batteries. This will help.
Posted on Jun 15, 2009
What do I check for to stop high fuel cosumption in my rx300 lexus
dragging brakes (brake calipers), under inflated tires, bad gas, bad spark plugs (beyond 50K miles on spark plugs).
Dec 26, 2014 | Lexus Cars & Trucks
My 2004 BA Ford Futura draws 0.12amps when its turned off,when its meant to be 0.01. Also stalls when driving,idles roughly,has huge loss in power and has a very high fuel cosumption.
Have you checked for engine trouble codes? How is your catalytic converter? If failed or plugged up, it might cause the problems.
Look in the fuse box or the power distribution box for an Ignition Off Draw, IOD, fuse. This is the circuit that should draw only the 0.01 amp. I wonder if you pulled that fuse, then checked for any remaining draw of amperage? Not sure if that is significant-...0,120, isn't that 120 milliamps? That's not much, even with an aftermarket amplifier and security system installed.
I recall an expert claiming if you stayed under 150 milliamps on the IOD, you were OK.
Of course if you were to try this, scan the computer for trouble codes first, memory will be lost, along with your radio pre-sets, your clock...your engine computer may have to go through a bit of relearning process...same as if you had the battery disconnected for any ,length of time.
The problems you are having, is it a sudden occurrence, or has it been building up for awhile? Think I would want a compression test, and check everything mechanical first, if no codes were found that jump-started you to the problem. Good luck, Ryan.
Dec 05, 2012 | Ford Futura Cars & Trucks
High fuel cosumption
Bad fuel economy is related to certain problems that you can repair.The air filter is the first thing.then you should perform a regular tune up.Spark plugs wires cap and rotor then you should replace you two 02 sensors.This will increase your fuel economy allot.Another item is your mass air flow sensor located on the throttle body.This tells the computer how much fuel to inject into your motor.
Oct 19, 2010 | 2003 Nissan Sentra
Almost new battery has overheated and boiled over after a 100 mile ride
Either you have a bad regulator/rectifier or you hooked up an accessory (fog lights,radio,etc.) directly to the battery. Drawing power directly from the battery and not drawing it from a power wire past the regulator/rectifier causes the charging system to go hay wire and boil the battery dry. Never draw power directly from your battery. Always hook accessories to a hot wire on the motorcycle past the regulator/rectifier.
Aug 31, 2010 | Honda CB 400 Four Motorcycles
I have Toyota corolla axio 2007 model 1.5 l car. The fuel cosumption seems to be very low and it is about 8.5 km /l. What should I do. Sujith
Clean the mass air flow sensor located just after the air filter...There are special cleaners but I think a home drycleaner should help but delicately applied ..I used a feather initially..Also some carburetoor cleaner and new spark plugs should help double that value of km/l
Aug 25, 2010 | 2007 Toyota Corolla
Oil cosumption
OIL CONSUMPTION COULD BE CAUSE BY WORN VALVE SEALS AND VALVE GUIDES WORN PISTON RINGS AND LEAKING OIL PAN GASKET.LEAKING FRONT AND REAR OIL SEALS.
Jun 07, 2010 | 2006 Dodge Caravan
How to minimize the gas cosumption of my nissan maxima 1989 model
some tips is your air filter must be clean if not replace it ,buy a repair kit for the carburetor and change it because parts are wear in.
Mar 04, 2010 | 1989 Nissan Pulsar
Excessive fuel cosumption in my 2002 nissan Xterra
need to have system checked to get a trouble code for light being on frist
Jan 19, 2010 | 1999 Honda Passport
the greatest thing you can do is to give it a full tune up. that consists of new plugs and wires. cap and rotor. air filter as well then change the oil and filter in both the engine and trans mission, make sure your tires are properly inflated as well. these changes should help the performance of the car. if you still feel that the milage is poor than i would suggest that you have the carburator adjusted and check the timing to insure that it's where it should be. hope this helps ....please rate this
Sep 09, 2008 | 1990 Acura Integra Hatchback
Samsung Digimax S500 Digital Camera Logo
50 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
