Perform a hard restart,hold the power button for 10 seconds while the system is on. The system will turn off. When you hit the button again, it will start and display the green start-up screen.
All your data is preserved, but cache is cleared and some settings are reverted and log-in or game start issues are resolved.
Alternatively, you can perform a full shutdown by going to SETTINGS / POWER & STARTUP and change POWER MODE from Instant-On to Energy-saving. After changing the setting, choose "Turn Xbox off". It can be powered back on by holding down the GUIDE button on the Xbox controller or the button on the front of the Xbox console. Once it's back online you can go back to SETTINGS / POWER & STARTUP and re-enable Instant-on.
I just had the same problem and managed to fix it.
Plug your controller into the PS3 via USB cable.
Put the PS3 into standby and then keep your finger on the power, every time it switches off hit the power button but keep your finger on it until you see the restore options come up
Press ok to any other screens
Select Restore file system
Power machine back up and all should be well.
All my games where still there and my settings so happy days. It now plays PS2 games as well, which it used to do but had stopped working a while back.
Turn the console to stand by, you can do this by pressing the power button for 10 seconds.
When it is on stand by (a solid red light shows) hold the power button for 3 beeps, remove your fingers on the third beep which should be a double beep.
This should take you to reset your console. You should see 6 options. Select option 2 then the system will go blank. Repeat the above but this time select option 3.
It could be that the settings on your ps3 are configured poorly for your television. Try fidling around with the output, and video settings form the settings section on the XMB. If none of this works then chances are your ps3 is broken.
Short answer its a ..... to fix. Theres multiple lasers in the disc drive that actually read the disc. The blue laser failed. Replacing the drive wont work unless you can reprogram the eeprom chip (or is it nand?) At any rate its just better to upgrade to a new console.
I had a similar problem. My PS3 did not start the disk based games.
Those disk based games were not visible in the game menu. I did not
have problems with the normal movie DVDs or Movie Blu Rays. Those were
working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3. 2. Hold the power button down; the system will turn on and turn off once again. 3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps 4. When you hear the 2 beeps take finger off power button. 5. You will be prompted to plug in your controller via USB and then hit the PS button 6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After
PS3 has executed the DB rebuilding operation, the disc games will be
visible again in the menu and are starting automatically when inserted
to PS3.
