Question about Samsung SyncMaster 740N 17" LCD Monitor
When I start my CPU, I hear a sound that shows me that the equipment is on (that it's working), but the screen stays completely black, no light, no image on it. It happened all of a sudden. I switched it off one night and next morning when I switched it on, the monitor was dead.
    Sergeant:
  • 361 Answers
That iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Posted on Jun 15, 2009
  • Roshan Rijal
    Roshan Rijal Jun 15, 2009
    that iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Dell e178wfpc monitor shows power on light but no display.
You should check if the vga cable is tightly connected from monitor to cpu. If the cable is connected properly,then the problem must be with your monitor. Check with any other monitor. If you hear a beep beep sound, when you start the computer then your RAM has been damaged or not properly connected.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
I have laptop by fujitsi it runs normally but the screen is completely black
When the display shows the following cases, that need to be replaced a LCD Inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 16, 2013 | Fujitsu Siemens KBPC SX Keyboard
I have VGC-LT23E all in one computer. It cost me a lot of money. When I turn on cpu I get nothing but a black/blank screen but I can hear the windows sound and fans are running. I just can't see...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 09, 2011 | Sony VAIO VGC-LT23E 22" PC/TV All-in-one
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
The laptop starts but yhe screen stays dark
The Keybinding to switch monitors is Fn F4. Please try this, and if it still doesn't work, listen closely and see if it keeps rebooting, also go into a dark room with the laptop, and see if the screen switches from black to dark blue and back to black. If this occurs, it's a result of your OS crashing. If this is the situation please contact a local retailer to see if you can get a new version of your OS for free, but you may be charged.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 11, 2010 | BenQ Joybook 8000 Notebook
My HP Laptop sounds like it is going to come on but the screen stays black but I can hear it running?
If you do not hear any beeps then try hooking the laptop to a VGA monitor via the back of the laptop...This will let you know if its the screen or not. If you have installed any new hardware i.e.RAM then remove it and reboot as it may not be compatible. If neither or those two work start unhooking hardware one at a time then boot to isolate the problem. (ram,harddrive, cdrom) if not presents itself then the CPU or mother is prob past away :(
Nov 02, 2009 | HP Pavilion dv1000 Notebook
Mitsubishi 1080 diamond tv screen turns off
Your tv has a lamp inside (refer to your user's manual) make sure is in good condition.
Mar 21, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Toshiba Satellite Notebook starts with black screen
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Acer Aspire 5100 Notebook
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Samsung SyncMaster 740N 17" LCD Monitor Logo
112 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
