Question about JRC 1000 MKII Radar GPS Receiver
Error BZ The radar does not work.
    Scholar:
  • 111 Answers
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Posted on Oct 30, 2009
We have a garmin gps map 4012 and on radar just says radar error
This is a marine chartplotter and radar unit! I thought I didn't recognize the model :>) Check the connections are the rear, but more importantly to the connections to the radar dome.
The manual is here, but doesn't mention errors. You could of course contact Garmin direct.
http://jsca.bc.ca/wp/wp-content/uploads/2013/12/Garmin-5008.pdf
May 03, 2016 | Garmin GPS
What year is Maytag model #7300, ser.#203594-BZ is?
According to the parts manual the Maytag A7300 is from June 1990. I'll upload the Parts List pdf.
Oct 30, 2015 | Maytag Washing Machines
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
It is showing Error Code "A"
"A" is not an error code. It means "all bogeys" and should be working fine
Aug 07, 2011 | V1 Radar Detector
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Could not connect to google talk service (error 1)
error 1 when using Google talk indicates that your firewall/security applications/software is bocking it
  1. turn off the firewall of the computer
  2. disable antivirus/antispyware programs
  3. it step 2 wont work, uninstall security programs then reinstall it
Jun 03, 2009 | Google Talk
Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Apr 19, 2009 | GPS
I have a Solo Radar Detector and all of a sudden when you insert the batteries and turn it on, it goes through the motions of turning on, then when done, the solid red light just blinks. I don't have a...
Well first off in doing so removing the batterys before you powered it off its stuck in some kind of error mode. Try putting the batteries in, holding the power button down for a few seconds and see if the light stops blinking.
Second Idea if you have a local radio shack they have replacment power cords for radar detectors there about 10 dollars. I had to go buy one for mine. After powering it up with that Id say it should work fine.
Feb 22, 2009 | Passport 8500 Radar Detector
Escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
Dec 30, 2008 | Passport 8500 Radar Detector
Garmin radar error code 8
check the battery, some error due to battery problems, and then rest it for a while and then test.
melnavz
Aug 05, 2008 | Garmin Boating
GPS Logo
519 people viewed this question
Top JRC GPS Experts
Marvin
Marvin
David Burbee
David Burbee
Will Halftowaite
Are you a JRC GPS Expert? Answer questions, earn points and help others
