Can't boot from FDD after upgrading bios. to version p20
Anyone can help me about how to make my FDD work again? after i upgrading my bios to version p20 my FDD can boot again. but when i try with different computer it works. any solution?
  • 50 Answers
Log in to the BIOD using the DEL button (most likely unless it says otherwise at the boot window), then you can change the boot sequence to have the FDD as the first boot drive.
Posted on Jun 15, 2009
I have a old Toshiba Portege 7100that i am trying to boot from a usb hardrive. When i start the computer up it says starting.Then 2 seconds later it says insert system drive and press any button to boot....
this model is too old to boot from a usb version1
maybe you can flash the bios to upgrade usb1 to usb version 2
or, load the ubuntu linux operating system using a CD
Sep 30, 2013 | Toshiba Portege 7100 Notebook
Hardlocks and or Resets!
It sounds like this bios may not be for your specific revision of motherboard. If you were upgrading the bios to solve a specific issue, check to make sure it's compatible with your board.
If you were upgrading the bios just because it's newer, this is always the wrong thing to do to a working system. Re-flash the board with it's original bios.
May 14, 2012 | Intel DP43TF Motherboard
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Satellite A20---is it possible to boot from external burner
you can try to install throu USB Drive. Search google there are many tricks how to bootup with your Pen Drive.
Feb 27, 2009 | Computers & Internet
PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
Oct 29, 2008 | Dell PowerEdge 1800 Server
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Can't install XP on Toshiba Satellite 2410-S185
you are on win 98? wow..that USB support is thin to minimal on that o/s
you may need to upgrade to another windows version for that..sounds like your computer has a few kinks and issues
Mar 19, 2008 | Computers & Internet
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
Even i experienced the same problem after updating BIOS....
There is a simple solution for it..... Just reboot the system and enter to Bios setup by tapping Del key
Press F9 key and set it to default settings... Just save and exit.... USB Ports works fine.....
Mar 17, 2008 | Computers & Internet
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
Alun Cox
David Payne
David Payne
