Question about Maxtor 20.4GB 7200rpm ATA-100 HDD p/n 5T020H2 ATA-100 Hard Drive
Someone just gave me a maxtor hard drive model 5TO20H2 how do i check to see whats on it. i may want to keep it as my master because i have no space on the hard drive im using and my windows is a pirate virson
  • bentaylor_be Jun 15, 2009
    THE STICKER IS MISSING TO THIS MAXTOR MODEL 5t020h2. where do i place the jumper on it to set as slave and or master. also can i use this hard drive? i belive the hard drive has a good copy of windows XP on it pluse it has more space on it the hard drive i have in now only has 10 GB and i have no money to buy a bigger one right now do i have to change anything in my comp to use this other HD HOW AND WHAT
  • Jim Sabba May 11, 2010
    you can install it as a "slave" harddrive by connecting it on the second spot on the IDE ribon (grey looking connection , connecting to first harddrive). but before you do that, you have to change to "jumper" to match the "slave" on the back of the second hard drive. then connecting it. so where you turn the computer on, the system wil see it as a second hard drive and u can see what is in it. and use it as a storage if need to be,
  • 50 Answers
You can install it as a "slave" harddrive by connecting it on the second spot on the IDE ribon (grey looking connection , connecting to first harddrive). but before you do that, you have to change to "jumper" to match the "slave" on the back of the second hard drive. then connecting it. so where you turn the computer on, the system wil see it as a second hard drive and u can see what is in it. and use it as a storage if need to be,
Posted on Jun 15, 2009
  • Jim Sabba Jun 17, 2009
    you can try to install it as you primary, without changing any jumpers, (since your friend mostlikely had it as his master), but the only thing is you drivers has to be changed to match. since if you put the harddrive as primary, you most likely are going to be able to boot from it, but it going to tell you or give you few errors (especially in device manager -if you right click on "my computer" click properties, then click hardware, then device manager- ), so it is not a smoot road. but it is worth a shot if you are willing to go that route. just remember to take your HDD off OR put is as a slave (so you can retrieve your documents from it.
    good luck.
Maxtor diamondmax
If you gave me a model number I could help you better, but here is what I can give you from what info you gave me.
Here is a spec sheet for the 3.5" drives since you seem unsure if it's 2.5 or 3.5:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/diamondmax_16_data_sheet.pdf
Here's a link to more information. Seagate now owns Maxtor:
http://www.seagate.com/support/internal-hard-drives/desktop-hard-drives/diamondmax/
Here's another link where you can put your model number in:
https://apps1.seagate.com/downloads/request.html
May 21, 2012 | Maxtor Hard Drive
Specs diamondmax16
Good Luck!
Pin settings to change Maxtor hard drive from slave to master
with no pins in it should be on master setting
Jul 09, 2010 | Maxtor Hard Drive
Windows don't recognize the slave drive
Check the "master" and make sure it is set to "master" and not cs (Cable Select)
Please gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Mar 25, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Can not find Jumper diagram on N256 Maxtor model 33073H3
Hello there soggytundra, here's your GEEK-steer ...
Despite your question being posted here 5 days ago, I'll presume you still (and if not, then someone else will) need the answer ...
Virtually all Maxtor drives adhere to the following general rules concerning jumper settings (at least up until now):
= MASTER (M): Insert jumper over the FIRST COMPLETE pair of VERTICAL pins.
Examples:
Xoo o oXooo Xooo
Xoooo Xooo Xooo
= CABE SELECT (CS): Insert jumper over the SECOND COMPLETE pair of VERTICAL pins.
Examples:
oXo o oXooo oXoo
oXooo Xooo oXoo
= SLAVE (S): Do NOT insert ANY jumpers (or at least NONE VERTICALLY, but you may HORIZONTALLY across the TOP row as simply a means of storing the jumper).
Examples:
ooo o ooooo oooo oooXX oooXX ooXX
ooooo oooo oooo ooooo oooo oooo
TIP: As a general rule, if you KNOW the role of the jumper capable device you're installing, it is better to NOT use Cable Select (CS). In this case you do, therefore it would be best to specifically designate the (33073H3) drive as (secondary) Slave [and your other (primary) drive as Master].
Good luck and GOD-speed. Please post back if you have any further questions, and/or just to let me (and others in similar need) know how well this steers to solution.
"Today's the best day of my life...and NOW you're part of it!"
Mar 28, 2009 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Maxtor 20.4GB 7200rpm ATA-100 HDD p/n 5T020H2 ATA-100 Hard Drive Logo
218 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
