Question about Craftsman Garden
Engine will not turn over where is fuse located model no. 917.270613 42' mower15.5 hp craftsman rider
    Scholar:
  • 81 Answers
Go to searspartsdirect.com and enter the model number 917.270613 on the right side of the page. This take you to a complete list of illustrations for your mower. Select electrical section and the fuse is #26 on the diagram. However, an engine not turning over can be the result of different problems such as a bad battery, ignition switch, solinoid (can you cross over the solinoid with a screwdriver to start the engine?), safety switch not working properly or even corrosion on the battery cables.
Posted on Jun 15, 2009
  • 284 Answers
Http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.270613&pop=flush
go here and find the electrical diagram and it will show you the fuse location
it is in the wire loom sticking out of it somewhere a green 30 amp fuse
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: i have a craftsman 42" rider model #917 259572
You will need the ignition coil replaced on your mower. It is a simple fix to do. If you could give the make and model number that is located on the side of the engine I will be able to direct you to the part you need.
Regards, Richard
Posted on Jul 26, 2011
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the fuse located in Model#917274640
It located inside the operator station. I usually find on the right most times but this can vary.
Most time when an engine won't start it is either the solenoid or a safety that is that problem.
Jul 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman rider wont stay running
Once having the same problem with the B&S engine, I had to replace the ignition coil. When it is in the process of failing, it acted as you describe.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Nov 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 550 brand new mower wont start
SONDS LIKE A FULE PROBLEM IT MAY NEED THE CARB CLEAND MAY HAVE BAD GAS
Oct 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Garden Logo
371 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
