Question about HP DeskJet 1220c/ps InkJet Printer
When I power up my HP 1220C printer, the power light goes on, it makes some noises and turns the drive rollers. Nothing else - the cartridges stay over to the far right. Then the feed rollers stop and the same weird noises, then silence and both the power and resume lights flash continuously. At this point nothing works - no diagnostics, nothing. Please help! (When I lift the lid, the cartridges don't move.) Thanks.
  • mackieprods Jun 15, 2009
    The problem was a "stuck carriage", which I fixed by forcefully "unsticking" it. All's now well. Thanks.
  • 75 Answers
IT COULD BE THAT THE INK SERVICE STATION CANNOT MOVE BECAUSE OF WATE INK.ALSO ADD SOME SEWING MACHINE OIL TO THE SILVER SLIDE BAR THAT THE CARIAGE RUNS ON.DONT GET OIL ON ANY OTHER PARTS
Posted on May 10, 2010
Printer won't turn on.
Common problem with this particular Printer is a Bad Power Supply,needs to be replaced,its nothing related to the cleaning you did.
you have Order a new power supply Board,open the back cover of printer and Install it.
Feb 04, 2012 | HP DeskJet 1220c InkJet Printer
Flashing Orange light will not stop printer will not print
THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
Feb 11, 2010 | HP DeskJet 1220c InkJet Printer
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
HP Deskjet 1220c won't print
This is a problem with the carriage. Unplug the printer from the wall and the computer wait half an hour and then plug it back in and see if you have the same problem please post the results.
Mar 02, 2009 | HP DeskJet 1220c InkJet Printer
Attention Light Is Rapidly Blinking Orange
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
Dec 24, 2008 | HP LaserJet 1300 Printer
Hp 1220c A3 printer not working
Had the same problem, some where there is a fix on the web, changing out a 1/2 watt resistor fixes it!
Feb 04, 2008 | HP DeskJet 1220c InkJet Printer
Not working
This maybe down to a faulty cartridge replace cartridges and then retry. You can try the following to obtain a test sheet.
  • Turn on printer
  • Hold power button down (While printer is on)
  • Press the paper feed button once
  • Release both buttons
This will printout a test sheet but I really do think that it is a faulty cartridge problem.
Hope I could help
Thanks J
Dec 08, 2007 | HP DeskJet 1220c InkJet Printer
HP 1220c problem
Did you try both cartridges? Sometimes a fried circuit on the color cartridge will cause a out of ink on the black even when the black is new. Double check that you are using the correct cartridge for the printer. and look at the copper/gold contacts in the printer where the cartridge goes. look for dried ink or tears. Clean with a Q-tip dipped in water. CAREFULLY. If it's torn.... enjoy your trip to walmart.
Aug 28, 2007 | HP DeskJet 1220c InkJet Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet 1220c/ps InkJet Printer Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
