Question about Emerson TS2587D 25" TV
How do i do a channel set-up on my emerson 25" tv
How can i do a channel set-up ?
I have a On top of that I have Direct. All of a sudden the direct comes on but no tv??? help
barbra_ron@qwest.net
Posted on Jun 15, 2009
My Emerson TV is stuck on number 1 channel how do I get it to go to other channels?
Need to go into the menu look for the channel setup then check the skipped channels make sure channel 1 isn't the only Channel not checked also Look at Your scanned channels in the channel list how many do you have is channel 1 it ? you may need to rescan your channels . If the TV worked OK before but Not now try resetting Your TV , BUT do this last as You will need to reset all the parameters in Your initial setup as well as rescanning channels also the Volume may blast you after reset I always install a set of earphones in the Audio phone jack first . To reset the TV Unplug it from the back of the set wait 30-40 seconds reconnect the plug while holding the Power Button Reset Your Options and Settings then Rescan your channels Don't forget the volume and to unplug earphones Good Luck
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
May 18, 2016 | Emerson Televison & Video
My Emerson tv model # eml20s5c won't get any channels from just a antenna, is it digital tv ? Do I need a converter
what input are you using it has to be set to air or antenna to get channels with an antenna .how old is the set it could need a converter if old enough
May 16, 2015 | Emerson Televison & Video
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
I need to program and set up my Emerson TV model TS1995
You should be able to go to emerson web site and print one.
Jun 25, 2009 | Emerson TS2587D 25" TV
My Emerson TS1995 television will only bring in channels 1-13. To view my full range of channels, I must go through the VCR. The original remote was lost for a long time, and I thought I would be able to...
theres a switch on back of tv that says cable or tv switch it to cable and that should fix the problem do you happen to have the remote for this i'm looking for a part # for that tv's remote email me at gerrywilson32@lycos.com if you have the remote thanks
May 17, 2009 | Emerson TS2587D 25" TV
Rolling lines a only a few stations
According to your post you seem to only be having the problems on the UHF channels. I would need to know what your source is IE: Antenna or Cable.
May 01, 2008 | Televison & Video
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
209 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
