Question about Home
When i flush water comes out of the bottom of the eco tank
When flushing water coms out of the bottom of the eco tank
    Champion:
  • 216 Answers
Bad tank to bowl gasket
Posted on Apr 26, 2014
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
SOURCE: Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Posted on Jun 30, 2009
  • 62 Answers
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
miket756
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
  • 150 Answers
SOURCE: Toilet flushing problem!
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Posted on Jan 20, 2010
How do i replace flush valve?
To replace the ballcock (flush valve):
  1. turn off water valve at wall
  2. flush2 times
  3. disconnect line from bottom of tank
  4. unscrew nut where line enters tank bottom
  5. remove lift device (Chain) from stopper at bottom inside tank
  6. lift the ballcock up and out of tank.
  7. replace withnew
  8. reverse to install.
mike
Nov 14, 2015 | Kohler K-3453-K4 Memoirs Comfort Height...
My flush has stuck on, how can this be sorted.?
Close the Inlet Water valve to the Flush Tank.
Remove the lid on top of the Tank cover.
Check the link/chord connecting the flush knob and the Flush valve.
It might be broken.
Normally the Flush Tank lever, which is outside the Tank lifts the Flush valve at the bottom of the Tank.
Nov 14, 2014 | Sport & Outdoor - Others
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
High limit switch gas hot water giant
Tank-type Gas water heater: high limit can the FV system, the ECO-TCO reset located on front of combustion chamber, or the one-time-use ECO located in the gas control valve thermostat probe.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-20.jpg
http://waterheatertimer.org/images/Gas-valve-ECO-124.jpg
Tank-type electric water heater has a reset button:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Other types: Tankless, indirect, boiler, solar assisted, hybrid, etc, please refer to product manual or add comment and describe the product in detail
Apr 07, 2013 | Water Heaters
My Rheem water heater is giving a ECO failure, How can I fix this?
Question posted under Rheem water heater.
Model number and gas valve are unknown. Add a comment.
Following information applies to typical tank-type gas water heater, and does not apply to tankless water heaters, boilers, indirect heaters, solar water heaters, etc or for electric water heater.
Electric water heater ECO is located on upper thermostat.
Open top cover and ECO can be reset by pushing in red reset button,
Or ECO can be replaced by replacing thermostat. Add a comment.
Open following link to see typical tank-type gas water heater ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
My toilet keeps leaking water and then fill ups on its own. Where could the leak be how do I fix it? Also I have to hold down the flush lever awhile for the toilet to completely flush. Can this be fixed ?...
If you are not getting puddles on the floor then it is probably the 'FLAP" that holds the water in the tank. It is the rubber part that is connected to your handle. Any hardware store will carry that part since it is an item that will fail, especially in hard water. It is probably the cause of both problems.
Jul 25, 2011 | Eljer & Titan Elongated Toilet Bowl
My Sani-compact toilet flushes on its own periodically. Why is this happening?
The seal at the bottom of the tank is leaking. Usually the call this a flapper. Take the top off the tank and look directly to the bottom of the tank in the center. Flush the stool and you will see the flapper rise and then fall. You probably need to replace the flapper. To do this just turn the water off to the stool, flush it to get all the water out of the tank, reach your hand in the tank and disconnect the flapper and now you can take it to most hardware stores and get another one.
Apr 10, 2011 | Home
Water constantly runs in toilet. occasionally will semi-flush on it's own. How do I adjust mechanisms to prevent this?
change the rubber flapper in the bottom of the tank. This is the way water stays or leaves the tank. You can find the flapper by taking the top off the tank. Flush the stool and you will see the flapper come up . it is at the center bottom of the tank. turn the water off to replace it, and flush the tank after you have turned the water off to get as much water out of the tank as possible to replace the flapper. you can get a new flapper at any hardware store for just a few dollars
Apr 08, 2011 | Home
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
Water comes from bottom of tank when commode is flushed. I have a two piece toilet, upon flushing it water pours from in between the two joined parts-tank and commode. I have the same problem. Water leaks...
Ok the toilets work is that the tank reservoir is where your fresh water....is stored....and the flush valve...(if you take the tank lid off you will see that the handle is either connected to a chain or uses a lever to lift something called a flapper....it is usually black but it can be gray..or blue...also there is a flash valve that is a long tube and a round bottom with a rubber gasket...that seals the flush water into the tank...reventing it from entering the bowl.......when you lift the handle water dumps from the tank...into a s-shape tunnel called a trap...(this is in place to prevent sewer gases from entering the house the water sits in the bottom of the trap acting as a seal against smells...gas...etc...from the sewer line....Now your tank is mounted to the bowl by (2 or 3) bolts that you can see and access from inside the tank...however the person doing this will have to also reach under the toilet where the tank mounts to the bowl and hold a pair of pliers or a crescent wrench on the nuts which hold the tank in place.....after these are removed...the tank will lift off of the bowl.(now obviously the water has to be shut off and be disconnected from the tank....when the tank is lifted ...a small amount of water may spill out ...but it is clean water...so no worries....since the tank and the bowl are made of porcelain they obviously would not seal just sitting on top of each other so the tank...has the bottom part of the flush assembly which is mounted to the tank by way of a large plastic nut extends out of the bottom opf the tank 2-3 inches......around this is another black or gray about 3-5 inches in diameter...and costs less than $5 at Home Depot.....change this out, reassemble and your back in business. Be advised that the flapper in the bottom of the tank...if you ever have to change it out and the tank gasket you are going to change out (after a long period of use or just time and deterioration)...leave black residue on your hands...if you handle them...but it is safe and easily washed off...it just may freak.. a layperson out....so one may want to use some gloves they can toss afterwards....Any other questions....and I can absolutely answer them in regards to toilets...as i have repaired and or replaced 2500 - 3000 in my 35 years in the apt/home maintenance industry.
I hope this helps.....thank you for rating my effort...and good luck....tha Fang.
Mar 29, 2009 | Home
Home Logo
51 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
