Question about ViewSonic VA1912wb Monitor
OSD stays on
The OSD screen became a permanent fixture in my monitor.  The buttons won't work; even the power button.  I changed my video cards and still the same.  I tried using DVI and analog cables but still no effect.  I also try to power off from the power cable and OSD did not budge.
  • 4 more comments
  • John Schwarz Apr 13, 2008
    I also have the same problem. Some days ago, after a year of trouble free usage, the OSD popped up and can not be closed. If it was not enough, the highlighted selection bar on the OSD's menu keeps jumping frenetically from one option to the other. It seemed like if one of the monitor buttons (the up arrow, in my case) were permanently pressed. When I press any other key (including the power button), the OSD slows down its frenzy, but the OSD still doesn't responds. As soon as I release the buttons, the OSD resumes its frenzy.
  • Anonymous Oct 09, 2008
    Even I am facing the same problem
  • Anonymous Oct 12, 2008
    same here... any ***** solution ?
  • mikemcg1 Nov 15, 2008
    same issue. is there a fix / any way to disable the OSD box from appearing at all perhaps ?
  • shulashula Nov 22, 2008
    Same here. I'm using a flat AOC LM720 for 5 years. recently the OSD pops up on it's on, as if the "menu" button is pressed. pressing the "auto" button somtimes makes it go away, but comes back on after a few sconds.
    is there a way to turn tho OSD completly off?
Same problem here... any **** solution ?
Posted on Oct 12, 2008
Why does a monitoring keep going off?
you forgot to say, screen dark? and power light off.
does the OSD work? Push button that pops up the OSD screen for bightness, does that work>
\can be one of 4 things. 100 % dead.
try it on another PC>
bad power cord
bad video cable.
bad LCD
bad PC, bad Video card in PC or some game using an illegal video card mode.
try another PC and see if the LCD works there.
easy huh?
Sep 30, 2013 | NEC MultiSync 1550V 15" LCD Monitor
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
The brightness icon stays on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
Oct 31, 2010 | Office Equipment & Supplies
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE:
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
On Screen Display is being shown permanently
Its aproblem of command section.Check its components one by can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem.
Jul 31, 2008 | SAMTRON 55V 15" CRT Monitor
OSD screen lock
The OSD is controlled by the video card board (logic board)
It is information stored on the eprom, not something you can just get to. It has to be programmed.
To gain access to the OSD Service Menu from a user service point you normally access it via a series of buttons on the control panel. Holding several buttons at once in a set combination that is particular to that brand, or even that individual series of monitor.
OSD just means "On Screen Display" the menu system and the service menu are the OSD.
Apr 21, 2008 | Computers & Internet
ViewSonic VA1912wb Monitor Logo
162 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
